1998 Trunk Issues
Old Jul 18, 2016 | 07:02 AM
Debbie Basque's Avatar
Debbie Basque
Cruising
Thank you. We have a Chevy mechanic looking at it today. We did remove the metal casing to the BCM and no oxidation was found on the board. I'm an electronic engineer and know how to clean boards and it did not help. Not to mention the board was fairly clean to begin with. I understand it's not a plug and play device but I'm not sure what other options we have. I suggested the FOBs creating the software issue only because it's possible there was malware or something that could have gotten into the software to mess it up. Again I'm an engineer so any kind of "computer" can be affected by malware or viruses or even hacked and because we've tried everything that's been suggested the only other option I can forsee is software, which is why we have a mechanic looking into it today for us. Thank you all for your advice. It's been super helpful and we wouldn't have gotten this far without it!!!
Old Jul 18, 2016 | 08:44 AM
73Corvette's Avatar
73Corvette
Well you certainly have the right occupation to be a C5 owner .... found a schematic that might be helpful...
Old Jul 18, 2016 | 09:54 AM
Debbie Basque
Cruising
Lol - Thats funny - thanks :-)
Old Jul 18, 2016 | 10:20 AM
Weck86's Avatar
Weck86
Ref Post #14, have you tried the simple stuff? Remove/check the hatch release button on the dash?
Old Jul 18, 2016 | 12:19 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Just pull the FUSE to see if it electrical or mechanical. I find it hard to believe to be a mechanical issue because BOTH latches are releasing at the same time.
Like previously stated, " Weck86 " I would start at the trunk release switch/button to make sure its not the issue. If nothing else, just disconnect it and see if the trunk stays SHUT!
YES, the BCM could be malfunctioning and telling the trunk release mechanisms to release on it own. I would eliminate everything ELSE before I replaced the BCM.
If you pull fuse #32, it will disable the trunk button.
