they keep opening
Old Jul 26, 2016 | 12:59 PM
FGVette's Avatar
FGVette
Default they keep opening
The 2 latches on my 1998 Coupe's air filter compartment keep coming undone. I snap them shut, go for a ride. then check on them and they are both unlatched. Anyone else have this problem and if so any fix for it?
Old Jul 26, 2016 | 01:12 PM
buckeye1872's Avatar
buckeye1872
Post from a week or so ago. May help you.
https://www.corvetteforum.com/forums...ping-open.html
Old Jul 26, 2016 | 03:44 PM
Make sure your air filter is fully seated in the air box.
Old Jul 26, 2016 | 04:04 PM
Mistrezz 06's Avatar
Mistrezz 06
Undo the whole box again and be sure the filter is all the way in. Every time I clean mine it takes me a little work to make the clamps stay close but they never pop open after I'm done. Good luck !!!
Old Jul 26, 2016 | 04:10 PM
popshumphrey's Avatar
popshumphrey
St. Jude Donor '16
Wow! Mine have been doing this since I had the car. I also have a second c5 that does it as well. I will try the bend, then the velcro, then... If you have any other ideas I am listening. Thanks for making this post!
Old Jul 26, 2016 | 08:31 PM
popshumphrey
St. Jude Donor '16
My latches on both my cars came open constantly. You could not drive 5 miles without them coming open. I took the advice and tried putting a 10 degree bend about one inch down from the latch. Went for a test drive. It worked! Just a simple bend in the strap seems to have kept them locked down.
To they keep opening
