Tree Sap Removal
Old Jul 27, 2016 | 03:30 PM
fatboy999's Avatar
fatboy999
Default Tree Sap Removal
Just wondering if anyone has a safe way to remove baked on tree sap from the paint?
Old Jul 27, 2016 | 03:55 PM
imjdoggie's Avatar
imjdoggie
Clay bar kit, Maguires makes one you can buy at any walmart, kmart, local parts store etc.
Old Jul 27, 2016 | 04:05 PM
the kid C6's Avatar
the kid C6
I'd start with a shot of waterless wash and a clean microfiber cloth. My experience with a waterless wash is that it will help 'lift' the sap.
Old Jul 27, 2016 | 04:20 PM
Try some Bug and Tar Remover - let it soak a bit before removing. Just make sure it is clear coat safe. You could also try some WD-40.
Old Jul 27, 2016 | 04:34 PM
Rico7142's Avatar
Rico7142
St. Jude Donor '16
Chadwicks
Old Jul 27, 2016 | 04:51 PM
JR-01's Avatar
JR-01
Originally Posted by Rico7142
Chadwicks
Old Jul 28, 2016 | 01:45 AM
Nasbluec5's Avatar
Nasbluec5
Goo gone will work as well
Old Jul 28, 2016 | 05:55 AM
ZigZag's Avatar
ZigZag
Remove tree problem solved.
Old Jul 28, 2016 | 06:43 AM
strand rider's Avatar
strand rider
I had a lot of pine sap across the entire hood. I wondered why the space under the tree was open, and, later on, I found out.
I didn't want to use a chemical solvent across the entire hood and fenders, so I used a claybar with a lot of lubrication , working the bumps and being gentle on the paint. Took a little while since the abrasion was so gentle, but no complaints about the results.
The advice about the waterless wash seemed promising, it probably would be a better way to start , and is not going to damage the paint as a more aggressive solution might.
Old Jul 28, 2016 | 07:23 AM
runner140*'s Avatar
runner140*
I've used WD-40 and Goo Gone with great results.
Old Jul 28, 2016 | 06:29 PM
Entovetter's Avatar
Entovetter
Before you try anything drastic, try washing it with water and your favorite car wash soap. Most likely the "sap" is actually honeydew, a sugary waste product expelled by aphids or scale insects feeding in the trees. Yes, it can bake on, but it's still water soluble. Trees don't just drip sap, unless the branches have been pruned, broken, or otherwise injured. Aphids and scales are common insects that cause the very problem you describe, and the stuff simply washes off.
Good luck!
Old Jul 28, 2016 | 06:33 PM
JR-01's Avatar
JR-01
Good luck!
Thanks for that informative post.
Old Jul 28, 2016 | 06:57 PM
v8srfun's Avatar
v8srfun
Mothers cleaner wax
Old Jul 29, 2016 | 12:55 AM
JETZ's Avatar
JETZ
Isopropyl rubbing alcohol!!
Takes off even old hard stuff like budda.
frank
Old Jul 30, 2016 | 01:06 AM
the kid C6's Avatar
the kid C6
PSA: Since we are more or less on the subject of trees, I wanted to remind everyone that this is nut season. I've been parking under the same tree in the parking lot at work for several months, but today I came out to find 10-15 nut shells scattered across my hood (insert "silent scream" emoticon).
I managed to rub out the marks, but I won't be parking in that spot for the next few weeks.
Be particularly careful of walnut trees, because green walnuts are quite heavy.
Old Jul 30, 2016 | 01:51 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
That reminds me of the time I hired electricians to install 4 fluorescent lights in the garage. One of the electrician unscrewed the bulb from the automatic garage opener and left it up there. Of course, he forgot to screw it back up. I drove out and when I came back, the vibration made the bulb fall on my hood (did not break). It sounded like an explosion had hit my hood. I had no idea what had happened until I looked around and saw the bulb on the ground. Luckily the hood had just a small nick which did not go too deeply into the finish. I raised hell with the company. The boss came over to take a look.
He agreed to give me a $100 credit on the next job. (not sure I will be using that company again)
Old Jul 30, 2016 | 02:52 PM
yanmar's Avatar
yanmar
Default tree sap removal
i vote for the clay bar,worked for me in the past. however there are other solutions..............
Old Jul 30, 2016 | 02:55 PM
Corvettewaldon's Avatar
Corvettewaldon
with Jetz...worked at detail shop for years. this works great!
To Tree Sap Removal
