Performance Budget
Old Aug 3, 2016 | 09:50 PM
DTA4's Avatar
DTA4
Default Performance Budget
I have an 03 z bone stock except for BB exhaust. Going to save over the winter and wondering (header, cold air intake) or cam? Each scenarios car would getting a tune. Just looking for best bang for my buck.
Old Aug 3, 2016 | 10:30 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
St. Jude Donor '18 thru '26
If you can only do one, headers is a good upgrade. If you're going to stay NA 1 3/4 is adequate. If your end game is SC, 1 7/8.
Old Aug 4, 2016 | 10:22 AM
I'd probably start out with the headers and CAI. With a tune, you'll notice a difference.
Old Aug 4, 2016 | 11:32 AM
slow-v6's Avatar
slow-v6
Headers, cai, and a fast 92/92 setup..
Old Aug 4, 2016 | 12:21 PM
DTA4's Avatar
DTA4
is there a lot of labor on putting on intake and how much does a 92 go for?
Old Aug 4, 2016 | 12:25 PM
garline14's Avatar
garline14
Headers, CAI, and tune to start off. Then u can add a heads/cam package later if u plan to stay NA. U can probably find a nice set of used headers/cai in the parts classifieds and save a few $$$
Old Aug 4, 2016 | 02:01 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Header and tune setup is going to be the best bang for the buck out there, short of nitrous.
Not only that but it is going to lay the ground work for any future mods you might want to do with the car.
Old Aug 4, 2016 | 02:10 PM
Black 02's Avatar
Black 02
You need headers and CAI to take advantage of a cam, so I would start there and do the cam at a later time.
Old Aug 4, 2016 | 02:15 PM
Rob Petyo's Avatar
Rob Petyo
The best bang for the buck IMHO has always been GEARs.
Open up the exhaust like mentioned above, a tune alone will probably surprise you with freeing up hp
Good luck!
If you are going on a dyno, try to get a baseline first and then see what each mod gains you.
Old Aug 4, 2016 | 02:59 PM
jimih941's Avatar
jimih941
The setup will be around $1250. I replaced mine in about 1.5 hours. Just make sure you're torquing it down to proper specs... the bolts will strip/break easily if too tight
Old Aug 4, 2016 | 03:38 PM
slow-v6's Avatar
slow-v6
New about 1200, used, can be found for 6-800. Hell even a fast 90 setup is awesome. I picked up .3tenths and 3 mph in my old 98 c5 switching from a ls6 intake TB, to a fast 90/90. You can also get 400-500 for your stock intake/TB.
To Performance Budget
