03 or 04 c5
Old Aug 5, 2016 | 03:50 AM
joeyo27's Avatar
joeyo27
Default 03 or 04 c5
I'm currently looking at a 03 and 04 c5. Both have 10000 miles both automatic coupe and both black on black and both are priced the same except the 03 comes with 2 targa tops one solid and one glass, the 04 just comes with solid top..I'm leaning towards 03 because of 2 tops..what do you think
Old Aug 5, 2016 | 03:54 AM
joeyo27's Avatar
joeyo27
Here's 03
Old Aug 5, 2016 | 03:58 AM
joeyo27's Avatar
joeyo27
Here's 04
Old Aug 5, 2016 | 04:10 AM
Tuco's Avatar
Tuco
St. Jude 15 Year Donor
From: Blessed are the cracked, for they let in the light.
St. Jude Donor '08 thru '26
03...just prejudice as I owned 2.
04 had the fuel tank issues? someone please correct me if this was also an 03 issue (which I never encountered)
After fixed they are the best of the C5's. Latest greatest improvement along the way.
Identical in everything, clear carfaxs?
Where did they spend their life?
Old Aug 5, 2016 | 04:12 AM
Tuco's Avatar
Tuco
oh...welcome to the forum.
Old Aug 5, 2016 | 04:21 AM
joeyo27's Avatar
joeyo27
04 is from Kansas then texas...03 Maryland then Virginia
Old Aug 5, 2016 | 04:46 AM
Tuco's Avatar
Tuco
Always like the south west for there should be zero corrosion issues, But given the low mileage and Mary/Virg, this should not be an issue...where are you from?
Factor the cost to pick it up into equation...either as a $$ thing or a Thing...I prefer the latter....it's a great way to get to know your new ride. Flew out to OKC and NO for 2 different ones.
Old Aug 5, 2016 | 05:09 AM
joeyo27's Avatar
joeyo27
I live in jersey..this will be my first vette...i can drive to virgina and see it and buy it...or have it shipped from texas...right now the 04 is $100 less with the shipping...both cars look immaculate from pics....
Old Aug 5, 2016 | 05:16 AM
Rob 02's Avatar
Rob 02
If one has the Z51 package I would get it. Look for modifications as well.
Old Aug 5, 2016 | 05:27 AM
joeyo27's Avatar
joeyo27
Here's 03
joeyo27's Avatar
joeyo27
Old Aug 5, 2016 | 05:29 AM
joeyo27's Avatar
joeyo27
Here's 04
Old Aug 5, 2016 | 08:19 AM
BlackandTan2004's Avatar
BlackandTan2004
If you can run the VIN's you may be able to see how they were optioned out. Someone on here may be able to help out with that. You may also want the G92 option which is a 3.15 rear as opposed to a 2.something.
Get the Black '04..... I am partial though
Welcome to the Forum.
Old Aug 5, 2016 | 08:24 AM
Corvette SSX's Avatar
Corvette SSX
St. Jude Donor '08
If the cars are really the same, I'd get the 03 for two reasons:
1. Two tops
2. No body side moldings
BTW, there should be a sticker on the inside of the glove compartment door that lists all the options, by option code, that the car came with.
Old Aug 5, 2016 | 08:26 AM
Rob 02's Avatar
Rob 02
You could ask for a cell phone pic of the production codes from their glove compartments. I agree with the 3.15 gears option.
Old Aug 5, 2016 | 09:41 AM
BlackandTan2004
Duh.... completely forgot that.
Old Aug 5, 2016 | 10:12 AM
cor28vettes's Avatar
cor28vettes
To my knowledge only 04 with a VIN range 45110258 - 45125500 and production range 10-22-03 through 3-19-04. Late 03 got the re-design which applied to 04 and C6. Old GM did a case be case fix but it was NOT a recall ever. That fix expired 10 yrs after the fact. Time is up.
Flaw in a batch of mold compound led to cracks & fuel vapor/fuel leaks of a quick connect on fuel crossover tank to tank.
16 pages on this thread
http://forums.corvetteforum.com/show....php?t=2480428
Pay attn to 8Vette7. He is an authority on this.
To 03 or 04 c5
Old Aug 5, 2016 | 11:55 AM
Both sound like nice cars. With the '04, check on the fuel tank issue as mentioned above. With the '03, it could still have the newer FFS fuel system depending on the build date of the car. 2003 gas tank changed with VIN 35111542 - beginning on November 25, 2002. However, seems like the '04s are the ones that have experienced the problem. My car has the FFS system and thankfully no problems at this point. In addition, consider how many times you will use both of the tops - the solid one could be handy in the hot summer, the lexan one the rest of the time.
I generally say buy the newest, best condition Vette you can, but this one would be a toss-up in my mind. I will say I have an '03 and it has been completely trouble free for the nearly 7 years I have owned it.
Old Aug 5, 2016 | 12:05 PM
S.C. vette's Avatar
S.C. vette
Veteran: Marine Corps
Take on the 04
Old Aug 5, 2016 | 12:26 PM
Rob 02's Avatar
Rob 02
If every thing is equal I would get the one that smells the best.
