Radio
Old Aug 8, 2016 | 08:39 AM
chevrolee's Avatar
chevrolee
Default Radio
Hi all, was just wondering if anyone has figured out how to add a usb port to our stock bose units instead of just the rca port. This would add a great deal of usefullness to our sound systems.Great forum by the way. I am aware of the add on units from dd,s I would like this installed directly to the face of stock unit.
Old Aug 8, 2016 | 01:12 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Call Dennis at DD... he is the absolute expert.. he knows all, in this area. He is a nice guy and will tell you if it can be done and how to do it. No obligation to buy anything.. he will put you on the right path or offer a solution.
Good luck
Bill aka ET
http://www.doubledmods.com/
Old Aug 8, 2016 | 07:07 PM
Mastertvtech's Avatar
Mastertvtech
I know there were kits to add the mini jack. If you got a peek at it's wiring diagram you could always buy a usb to rca adaptor, modify it and wire it into the radio. You would need to find 5 volts inside the radio, ground and the audio input points. I would mount the usb in the faceplate and cut off the Rca for video and run the wires you need into the radio itself.
To Radio
