Torque management
Old Aug 16, 2016 | 01:50 PM
TheBandit18's Avatar
TheBandit18
Default Torque management
So i just wanted to clarify my vette is sluggish in 1st gear till about 4000-4500 rpms, then when shifting to second i can get a chirp. Is that the torque management coming into play?
Old Aug 16, 2016 | 06:32 PM
dbgoodwin's Avatar
dbgoodwin
Does it say "traction system active" or anything like that at any time?
a4,m6,or mn12?
Old Aug 16, 2016 | 07:24 PM
TheBandit18
Its a 99 frc it doesnt read anything it does it when i press the traction off or on
Old Aug 16, 2016 | 10:30 PM
TheBandit18
The only code i have is the tcs 1286 steering wheel alignment. I have to turn it 360° to the right
Old Aug 16, 2016 | 11:02 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
When I first bought my 99, I thought it was real doggie in first and second under hard throttle. Felt like something was holding it back, would not break the tires loose, then turned off the TC and when under hard throttle in first and second it immediately smoked the tires !!!! (for what that is worth) The TC applies brake on spinning tire and retards the timing.
Old Aug 17, 2016 | 06:10 AM
TheBandit18
Is there something elsw i need to do than just press the TC button tonturn it off?
Old Aug 17, 2016 | 08:25 AM
jimmyLSX's Avatar
jimmyLSX
No, as soon as the corvette fishtailing shows up below the speedo tach then traction control is disabled.
Old Aug 17, 2016 | 09:45 AM
TheBandit18
So my guess is it is the torque management. Becuz i drove a z06 and it ripped the tires off. Tire hieght wont change that will it? It does have a taller tire in the back than factory
Old Aug 17, 2016 | 09:53 AM
jimmyLSX's Avatar
jimmyLSX
What year and mileage is on your C5? You give it a tune up yet? The only reason the C5 Z06 lights em up easy is because of the first three gears, its what makes it feel like an animal compared to a normal C5 put in some 3.90s and you can spin them at will also.
Old Aug 17, 2016 | 09:59 AM
TheBandit18
1999 110k miles. Im not trying to just spin them im just trying to get a better response in first. I am about to check spark plugs, oil is good. But like i said im surprised how fast the car is except for beginning of first.
Old Aug 17, 2016 | 10:59 AM
jimmyLSX's Avatar
jimmyLSX
If you're bonestock I would upgrade the air intake to breath more, the stock airbox on C5's are chokers on 97-00 and a hole as wide as two fingers was put on the 01-04 airbox. Also if you're still on the stock plugs I would replace them with some NGK's TR5 the ones gapped at 0.040 or another set of oem ac delcos that come gapped at 0.040. Also make sure to buy some wires also if those are the stock plugs you want get them all off without ripping one .
Also Fwiw if the engineers never changed the throttle on 1997-00 to 01-04. Then u should get more throttle response from traction control on.
Only when u go WOT and shift does torque management mess with the drivetrain. Ive found best throttle response with TC on > TC off > competitive mode.
Old Aug 17, 2016 | 11:04 AM
TheBandit18
Ok it might also be i came from a camaro that has the tr6060. Also had it cammed so might just be me
Old Aug 17, 2016 | 11:12 AM
jimmyLSX's Avatar
jimmyLSX
You just need mediCAM or/and mediBLOWER and you should be back to being better then before.
Old Aug 17, 2016 | 11:17 AM
TheBandit18
Trust me that will be very soon!
Old Aug 17, 2016 | 11:50 AM
grantv's Avatar
grantv
If it's the way the earlier C5's are then it reminds me of my buddies "old" Mercedes SL500. The car actually had some oomph to it, but if it didn't hook right it was a dog. Poor traction control system IMO.
My 04Z has a much better system, better than my previous BMW's as well.
Old Aug 17, 2016 | 12:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When you mash you foot to the floor,,, the THROTTLE BLADE "DOES NOT" whip open to full throttle!
YES,, "Torque Management" only opens it at a smooth and predetermined rate.
SO,,,,, If it were me,,, and I wanted more aggressive throttle response, I would get a PCM Mail order tune.
I know Chuck COW at Corvettes Of Westchester has an outstanding Mail Order Tune and also includes a throttle response enhancement that makes the Accelerator Peddle more linear and aggressive..
Give him a call. The Mail Order tune isn't all that expensive but it makes the car a LOT MORE FUN!
BC
Old Aug 17, 2016 | 06:27 PM
TheBandit18
I will definitely look into that! I am soon to be getting headers and cold air so ill be getting a tune
To Torque management
Old Aug 17, 2016 | 06:37 PM
foggy's Avatar
foggy
1999 doesn't apply the brakes.. just engine management..
Later than 2000 sometime they added the braking along with
the torque mang from engine ... fyi
Old Aug 17, 2016 | 07:22 PM
TheBandit18
I did try it with and without TC and first gear felt the same, shifting to second i felt it activate the torque management but it was after it chirped the tires and was on the gas again (guess i shift faster than the computer can think)
Old Aug 17, 2016 | 07:35 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
This is from the 99 service manual ?????
TRACTION CONTROL SYSTEM (TCS)
The Traction Control System (TCS) uses spark retard, throttle close-down and rear brakes to enhance vehicle
acceleration and stability. TCS is capable of functioning up to maximum vehicle speed. Traction control is
given priority at low vehicle speeds. Directional control is given priority at high vehicle speeds and during
cornering. During a cornering maneuver, difference in front wheel speeds is monitored to detect cornering.
During low vehicle acceleration, control strategy is more sensitive.
The TCS is capable of simultaneous or separate usage of engine control (spark control and throttle close-down)
and rear brake intervention. When a TCS event occurs, TCS disables cruise control and torque converter clutch
(automatic transmission equipped vehicles). Traction control logic uses a reference speed from the non-driven
front wheels. A sophisticated slip threshold calculation considers vehicle acceleration, vehicle speed, cornering
and start-up. There are rear wheel acceleration rates which will trigger rear brake intervention to reduce wheel
spin.
