low voltage at idle
Old Aug 31, 2016 | 09:59 AM
elayhotajohnson's Avatar
elayhotajohnson
4th Gear
Default low voltage at idle
low voltage at idle
Old Aug 31, 2016 | 05:12 PM
73Corvette's Avatar
73Corvette
Are you saying the DIC is showing low voltage? What does it show? A bit more info might be helpful..
Old Aug 31, 2016 | 05:21 PM
gimp's Avatar
gimp
replace alternator and battery
(See, if you provide zero details, you'll get zero details in response.)
Old Aug 31, 2016 | 06:09 PM
grantv's Avatar
grantv
That's OK, my reply was going to be "Yes, low voltage at idle"
Old Aug 31, 2016 | 08:03 PM
Fed Up's Avatar
Fed Up
"My Dad's a TV Repairman"
Might as well just go ahead with alternator, battery, belts, pulleys, plugs, wires, coils, ECU, MAF, TPS, CTS and quite possibly the engine wiring harness- Got to be thorough with those daggone electrons running around!
Oh. Experience speaking here. Replace this thing:
Old Aug 31, 2016 | 08:08 PM
Ducati Guy's Avatar
Ducati Guy
Man...............you guys are harsh..........he he he.
Old Aug 31, 2016 | 09:01 PM
gimp's Avatar
gimp
It depends on what "is" is.
Old Aug 31, 2016 | 09:04 PM
73Corvette's Avatar
73Corvette
don't have thin skin.... these guys are just razzing you... we do need more info and then some of them can help you out...
Old Aug 31, 2016 | 09:29 PM
novasscnc's Avatar
novasscnc
Put a multi meter on it
Old Aug 31, 2016 | 09:53 PM
GCG's Avatar
GCG
Originally Posted by elayhotajohnson
low voltage at idle
OK, let's troubleshoot!
Old Aug 31, 2016 | 10:45 PM
Ducati Guy's Avatar
Ducati Guy
Damn...............that is funny.
Old Aug 31, 2016 | 11:48 PM
Ducati Guy's Avatar
Ducati Guy
Originally Posted by thisMSGgood4me
It sure is, and if I'm not mistaken, it was originally from the late Mr. Sam aka dadaroo.
I think the OP problem is transmission related. This video should help.
Old Sep 1, 2016 | 01:11 AM
Rob 02's Avatar
Rob 02
Have you checked the battery?
Old Sep 1, 2016 | 07:44 AM
GCG's Avatar
GCG
It's probably the Flux Capacitor
Old Sep 1, 2016 | 11:45 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I would add to the HOOPLA but, I am sure that the OP really does have an issue and would like to SOLVE IT.
SO,, here goes.
Please use a volt meter and read the terminals DIRECTLY on the battery when you see the LOW VOLTAGE reading.
The volt meters inside the car (digital & ANALOG) are NOT showing you the actual battery voltage.
They display the voltage on the HOT in RUN & START or HOT in ON and RUN DC buss. That buss comes from the IGNITION SWITCH output! If the ignition switch contacts are dirty/burnt, it can cause a low voltage issue for that buss.
The BATTERY recharge path comes from the large connection on the back of the alternator "BATT TERMINAL" It then goes to the STARTER SOLENOID main terminal and then it goes to the battery POSITIVE Terminal. If the starter solenoid main terminal is dirty/loose or corroded, it can effect charging voltage.
Bill
Old Sep 1, 2016 | 04:23 PM
gimp's Avatar
gimp
Negative, it's XKCD:
https://xkcd.com/730/
Old Sep 4, 2016 | 10:22 PM
elayhotajohnson
4th Gear
Default Low voltage at idle #2
2000 vette coupe 59,000 miles: My voltage meter(in the dashboard) would read as low 11.8v at idle with ac and head lights on. I used my hand heald volt meter it read 12v at idle with same loads. I had the alternator checked while on the car at o'rilleys (car was at operation temp) and they said the alternator (GM original)was bad. on 8-30-16 I bought a rebuilt (only kind they sale) altenator from Auto Zone (they had 20% off sale). This replacement AZ rebuilt altenator would read 14.1, engine cold at idle with ac, head lights on. after the engine warmed up to 180 degrees (about 9 miles of driving) the voltags (dashborad gage) would drop to 13.5 at speed 30+mph, but would drop more to 13.1 -12.8 at idle. I then had my origianl GM altenator checked, off the car at AZ, and they said the GM altenator was ok????, Now i am thinking to replace the voltage regulator in my GM original altenator and taking the AZ altenator back for a refund???
To low voltage at idle
Old Sep 4, 2016 | 11:29 PM
GCG's Avatar
GCG
If you still have your original alternator, KEEP IT! Do not give it back as core. Plenty of horror stories here, just do a search on the subject.
C5s are very "picky" with alternators and when these are not replaced with the right ones, it causes charging system fault codes.
When your car is showing low voltage, have you checked what voltage you have between the alternator and the battery's positive post? It should be zero or very, very close to it. If it is significant, you probably have a bad contact at the starter or a bad fusible link. The chain is alternator-starter-battery.
Old Sep 5, 2016 | 02:01 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Try this before you replace the regulator :
Old Sep 5, 2016 | 07:31 PM
SG Lou's Avatar
SG Lou
New Guy.....
