No Start Z06
Old Sep 11, 2016 | 03:57 PM
jslym777's Avatar
jslym777
Default No Start Z06
Nice day in Ohio today. Took my car to the self serve car wash. All clean but the car wont start. Clutch in, turn key and one click. Engine won't turn over. Of course this happens away from home....
Old Sep 11, 2016 | 04:08 PM
rrwirsi's Avatar
rrwirsi
OK, how did you get it home? Had the same thing happen to me. I took the key out, washing it with a bottle of water, dried it, inserted it several times and wala it started. That was about a year ago. Have not had any further issues. I did spray electric cleaner into the key assembly.
Old Sep 11, 2016 | 04:13 PM
jslym777's Avatar
jslym777
Unfortunately I am not home. I am sitting in the wash bay...
Old Sep 11, 2016 | 04:18 PM
jslym777's Avatar
jslym777
It has a new TDR in the foot panel passenger side. Checked fuses, look ok.
Old Sep 11, 2016 | 04:35 PM
jslym777's Avatar
jslym777
The security light in the dash is blinking when I open the door.
Old Sep 11, 2016 | 06:33 PM
jslym777's Avatar
jslym777
No luck. Tried jumping. Cleaning key. Checking wires. Swapping relays.... towed to the shop...
Old Sep 11, 2016 | 07:09 PM
Ducati Guy's Avatar
Ducati Guy
Well at least it's clean.
Old Sep 11, 2016 | 07:57 PM
JR-01's Avatar
JR-01
One reason why I do not use water to wash my car.
Old Sep 11, 2016 | 08:13 PM
jslym777's Avatar
jslym777
I've really had nothing but problems with this car. Pushing my last straw lol
Old Sep 12, 2016 | 10:02 AM
jslym777's Avatar
jslym777
Update:
Shop said the starter is fine...
Old Sep 12, 2016 | 10:17 AM
ThePeoplesChamp's Avatar
ThePeoplesChamp
It might be an unrelated thing such as crankshaft position sensor. Mine randomly went out and my car would not start. good luck
Old Sep 12, 2016 | 11:09 AM
cor28vettes's Avatar
cor28vettes
Update:
Did they say starter solenoid was fine too? There is a difference.
Old Sep 12, 2016 | 11:16 AM
cor28vettes
Originally Posted by 8VETTE7
Did you check to see if any water has gotten in on the passenger side of the car due to blocked wiper well drains???????? Several relays (TDR included) and the BCM are on that side...
If no water then start checking the other things mentioned in my first post.
And water intrusion from washing the car. Check behind carpeting/floorboard pass side.
Far as solenoid...I had issue X2 with my low mileage 03. Rec'd tip to strike the solenoid with wood while someone turns key. Started right up.
I had everything (lights/radio etc) when issue presented itself.
Old Sep 12, 2016 | 11:20 AM
cor28vettes
Default Explore this
http://forums.corvetteforum.com/show....php?t=3873363 post #12
Old Sep 12, 2016 | 11:22 AM
jslym777's Avatar
jslym777
Shop said they think it has something to do with the theft system but the relays are all good. Told me it will have to go to the dealer for diagnostics if their 'reset' procedure doesn't work
Old Sep 12, 2016 | 11:32 AM
jslym777's Avatar
jslym777
I have no options. I am 150 miles from home and it was a sunday.
Old Sep 12, 2016 | 11:44 AM
cor28vettes
Default 5 pages
http://forums.corvetteforum.com/show....php?t=2763463
To No Start Z06
Old Sep 12, 2016 | 12:31 PM
jslym777's Avatar
jslym777
Just got a call from the shop. Said they can't fix it. Have to tow it to dealer...
Old Sep 12, 2016 | 12:33 PM
JR-01's Avatar
JR-01
How much are they charging you to not fix it?
Old Sep 12, 2016 | 12:50 PM
jslym777's Avatar
jslym777
I am at the shop now. It will crank and start up by jumping the starter or TDR but will not stay running. A key recognition problem?
