TPMS - Error Code "Lxxx"
Old Sep 11, 2016 | 08:06 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Default TPMS - Error Code "Lxxx"
Received this code today for my front driver's side wheel/tire. Does that mean the tire pressure sensor for that wheel is dead or can it be reprogrammed? The Check Tire Sensor System warning also appeared on the DIC. I checked the tire inflation manually and it appears fine. Thinking the sensor is starting to go.
Old Sep 11, 2016 | 09:08 PM
Robert Perkins's Avatar
Robert Perkins
Time for new sensors battery is probably dead others will follow.
Old Sep 12, 2016 | 12:03 AM
MSG C5's Avatar
MSG C5
Thanks. This particular sensor has been going on and off over the last week so I will try retraining them. These are not the original sensors but the secondary sensors I installed with my CCW wheel/tire package in 2012, so they are only 4 years old.
I hate the idea of removing the tires to replace the sensor and would prefer to swap out the sensors when I replace the tires.
Old Sep 12, 2016 | 09:06 AM
Pappy11's Avatar
Pappy11
Mine started doing that....I ended up replacing all 4 Tire direct had them for 42.00 each for my 02...no more problems
To TPMS - Error Code "Lxxx"
