Tire sealant
Old Sep 14, 2016 | 05:51 PM
Omaha Flash's Avatar
Omaha Flash
Default Tire sealant
HAS ANYONE USED TIRE SEALANT IN NON RUN FLAT TIRES AND IF SO, DID IT AFFECT THE TIRE PRESSURE MONITORING SYSTEM?
THANKS IN ADVANCE.
Old Sep 14, 2016 | 06:04 PM
JR-01's Avatar
JR-01
I did and no it didn't. Took it to tire shop, they wiped the tire out and patched it.
Old Sep 15, 2016 | 02:55 AM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
Forget it. Don't ever use it. There's a reason why they sell it at WalMart. I tried it on my GF's Mercedes with custom wheels and tires akin to our Vettes; and it was total waste of time, money, and energy to clean that nastiness. I had to have the wheels/tires broken down, take them home and pressure wash them all; and then start over.
PS, you can't pressure wash the inside of a tire without getting whatever is in the tire all over you. Ask me how I know. that.
If you don't have a leak in the tire, you likely have a cracked wheel or some corrosion around the bead somewhere allowing air to escape. Get it fixed right. One of the best tire shops I have found is the Quick Lane Service attached to my local Ford dealer. Yes, they take care of my Corvette wheels/tires and everything else too.
Old Sep 15, 2016 | 07:34 AM
JR-01's Avatar
JR-01
You need to break the tires down to properly patch the tire anyway. It should only be used in an emergency, not to seal a leaky valve or bead.
It saved me a ton of money, didn't have to get a tow and was back on the road in a minute. Seven bucks for the can of sealant and 15 bucks to get the tire patched. That was three years ago and not a problem with that tire since. The TPMS works fine.
Old Sep 15, 2016 | 08:18 AM
Omaha Flash
Thanks for all the replies. My thought in possibly using a tire sealant was the fact that i do not have the "run flat" tires on the car now and having the sealant in each tire might prevent a costly flatbed charge to a tire shop if i had a flat tire. I really wouldn't use it to permently seal a leak, but rather just get me to a shop to have the tire repaired/replaced.
Old Sep 15, 2016 | 09:26 AM
JR-01's Avatar
JR-01
I have used it for punctures several times over the years without problems. I do not have run flats and carry a can in all my vehicles, just for emergencies. I would not fill the tires with sealant as a preventative measure.
Old Sep 15, 2016 | 09:29 AM
JEH03Vette's Avatar
JEH03Vette
I went through this about a month ago. Used the Slime that is TPMS safe. The tire shop had no problem wiping it out and patching the tire.
Old Sep 15, 2016 | 09:45 AM
JR-01's Avatar
JR-01
It can save you a bunch of money and get you home when you get a flat. Despite what some people believe, it really is a great product.
Old Sep 15, 2016 | 10:55 AM
Omaha Flash
THIS IS EXACTLY WHAT I HAD IN MIND, JUST DIDN'T WANT TO DAMAGE THE TPM SENSORS.
Old Sep 15, 2016 | 03:46 PM
terrywerst's Avatar
terrywerst
The sensors are safe. They tell you on the back. Only buy the cans with the TPMS safe labels.
Old Sep 15, 2016 | 05:16 PM
rrwirsi's Avatar
rrwirsi
Another option is to buy a portable 12DCV air compressor and keep it in your car for those times when a nail is in the tire or a slow leak occurs. Using the compressor, just pump your tire up to 45 lbs and drive until you reach home or a repair shop. If the warning pressure warning comes on again, just stop, put more in, and to go again.
Old Sep 15, 2016 | 06:05 PM
formula1nut's Avatar
formula1nut
My car is really low so if a tire deflates on the road I am potentially in deep trouble. I do not have runflats so carry both a mini compressor and the sealant. Sealant is not much good unless you can get air into the tires!
Old Sep 15, 2016 | 06:09 PM
JR-01's Avatar
JR-01
It comes with the air already in it. Takes about 20 seconds to get back on the road and out of harm's way.
Old Sep 15, 2016 | 07:06 PM
JR-01's Avatar
JR-01
Originally Posted by thisMSGgood4me
To me, using a sealant is the last resort. First I would try just airing the tire up with a portable air compressor I carry in one of the rear compartments and see how far that would get me (if the air leak is slow). If I couldn't get very far without having to air it up repeatedly, I would then go to removing the screw/nail and plugging the puncture with a plug kit I carry (which should get me where I need to go, a tire shop where it can be properly repaired with a plug/patch combo). As I said, a sealant would be the last resort because of the mess it makes inside the tire. I know some people don't have a problem with that, but the stuff is not for me, which is why I don't carry it.
I have never had a tire shop guy complain about wiping the "mess" out of the tire. It really is not a big deal. I watched him do it. Took him a couple minutes and a couple paper towels. He then patched the tire.
Would you rather be on the side of a busy freeway for 60 seconds or 5-10 minutes? Your choice.
Old Sep 15, 2016 | 07:32 PM
JR-01's Avatar
JR-01
Who says you have to be "on the side of a busy freeway" for ANY amount of time? Even if the tire is losing air pressure, I could still drive to where it's safe to either air it up or use the plug kit to fix it (if need be), like in a parking lot or a side street off a busy street. You're making the false assumption that punctures seem to occur only on a "busy freeway" and that's where you have to deal with it. You don't, and that's my point.
I have seen a lot of cars on the side of the freeway with flat tires. Punctures can occur anywhere and tires can go down real fast. It could be quite a distance to the next exit. That's why I use it.
The inflator/sealer is the quickest and easiest way to deal with a flat tire and get back on the road. Now if you can't handle the mess inside the tire then don't use it.
I never said punctures only occur on busy freeways. It was just an example of where it would be dangerous to deal with a flat and mess with a compressor. I do carry both.
Old Oct 5, 2016 | 09:15 AM
JR-01's Avatar
JR-01
Tires don't usually go down real fast. Usually when you pick up a nail or screw, which is typically why a tire loses air pressure, the tire goes down rather slowly, slow enough to be able to pull off the road to a safe location to deal with it. Especially if you've got TPMS that's working for you to alert you to the loss of air pressure.
Good for you, Jr, that you carry both. I'm happy for you!
You don't seem to understand. A wise person plans for the worst case scenario, not having a slow leak or a tire going flat in your driveway or in front of a tire shop. Punctured tires do usually loose air slowly, but I have had them go down real fast so I plan for the worst case, not the best. Better to have the tool and not need it...........
JR-01's Avatar
JR-01
https://www.getairhawk.com/airhawkwe...a-981e9149912f
To Tire sealant
Old Oct 5, 2016 | 02:46 PM
jjc508520's Avatar
jjc508520
Quick Lane - good choice - they sponsor an NHRA team and I saw them at Reading PA (Maple Grove) this past weekend - in between downpours!
Old Oct 5, 2016 | 03:31 PM
JR-01's Avatar
JR-01
Au contraire, I in fact do understand. I plan for the far more likely scenario (which still is not that likely to happen), not for something that is even further less likely to happen. But if that further less likely to happen scenario does actually occur, I've got a phone to get me out of a jam. That's my plan for handling those scenarios that happen so very rarely that it's just not worth it to me to carry something I don't even want to use.
Do you keep a gun in the house for protection even though it is extremely rare that you would ever need it or want to use it? I would rather be prepared instead of counting on a phone to get me out of a jam. That's just me.
Old Oct 5, 2016 | 04:02 PM
JR-01's Avatar
JR-01
You make a good point about a gun in the house. However, I want a gun in my house for protection, while not wanting a can of slime in my Vette, because I'll never use that can of slime in my tires, while I will use a gun in my house for protection should the need arise. Do you see the difference now?
Why don't we just agree to disagree, ok, Jr?
Just like a gun, the slime is the last resort. Many people are killed or injured dealing with flat tires on the side of the road. Some would still be alive if they had a can of slime instead of trying to change a tire. I have used the stuff several times without a single problem. Got me back on the road in seconds instead of minutes. Just because you won't use it doesn't mean others shouldn't. It is a good product.
I agree that we disagree.
