Hood struts, replacement?
Old Sep 24, 2016 | 02:29 PM
Lord.Baal's Avatar
Lord.Baal
Default Hood struts, replacement?
Hi all,
my hood struts no longer keep the hood up for more then a few minutes then it slowly falls back down. i decided to buy replacement struts but no instructions!!
does anyone have a set of instructions or know where i can find a youtube or instruction list on how to replace them?
or can anyone help explain exactly what i need to do to pull the old ones off and put the new ones on. i am mostly unsure where the connecting points are...
thanks!!
Old Sep 24, 2016 | 03:14 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
http://www.ebay.com/gds/How-to-Repla...4835871/g.html
Old Sep 24, 2016 | 03:16 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
small screwdriver..pop off clip on retainer....snap new strut on...easy peasy
Old Sep 24, 2016 | 10:26 PM
Works great.
Old Sep 25, 2016 | 02:00 AM
Lord.Baal's Avatar
Lord.Baal
Thank you!!! I'll check out that video. Was hoping it was easy. I swear nothing on a vette is easy to replace.
Front turn signal
Hope this goes faster
Old Sep 25, 2016 | 04:43 PM
Paul Wood's Avatar
Paul Wood
I did mine in about two minutes. The first one I flung the clip several feet and had to look for it. That took about 15 seconds of the two minutes! Very easy job. Good luck.
Old Sep 25, 2016 | 06:33 PM
Carl Timonen's Avatar
Carl Timonen
You're lucky. If it were me, it would've flown into a dark crevice behind a stack of stuff that hadn't been moved for many moons.
Old Sep 26, 2016 | 02:10 PM
Brit dex's Avatar
Brit dex
Is it the same type for convertible roof cover... Sick of it closing on my arm when I'm putting rough down ��
Old Sep 26, 2016 | 05:28 PM
Lord.Baal's Avatar
Lord.Baal
Thanks. Was super easy...except one of the struts was broken. So 1 replaced...lol
Should be real easy on the second when I get one that is intact
To Hood struts, replacement?
