2002 corvette
Old Oct 1, 2016 | 03:38 PM
shutout's Avatar
shutout
Default 2002 corvette
I will be looking at a 2002 6-speed corvette coupe once the weather clears up. The car has only 11,500 miles on it. As far as I know it is not stored in a heated garage.
I'm concerned that with such low miles and lack of use I will be dealing with leaks and dry rot.
Any input would be much appreciated, thanks.
Old Oct 1, 2016 | 04:31 PM
Just check the car over carefully. If the owner drove it somewhat regularly to keep things lubricated, it could be that you won't have any leaks.
Old Oct 1, 2016 | 05:05 PM
shutout's Avatar
shutout
I'll definitely go over it very closely, thanks.
Old Oct 1, 2016 | 05:24 PM
S.C. vette's Avatar
S.C. vette
Veteran: Marine Corps
Look at every inch of the weather stripping and feel all along all fluid hoses for deterioration or cracking. If nothing else, I would be considering the replacement of all fluid hoses in the near future... after all the car is approaching 15 years.
Old Oct 1, 2016 | 08:27 PM
shutout's Avatar
shutout
Good advice, I appreciate it.
Old Oct 1, 2016 | 08:49 PM
Roddy13's Avatar
Roddy13
I had this with the last car I bought from an older gent. I think it had sat for 3+ years... Showed mint, got it home... 2-3 drives later OMFG!! The fuel was bad all kinds of detonation going on, every gasket related to airflow ... Intake, tb, etc was brittle and causing idle surges, sensors were failed and then came the oil leaks... The car might as well have had 300,000 miles on it... Basket case...
Check the basics, tires, brake lines, how it was stored. You might be fine, but I'm no longer the guy that shops for the ultra low mile cars anymore
Old Oct 1, 2016 | 08:55 PM
nascar03's Avatar
nascar03
Hey shutout.
Was it stored outside or a non-heated garage?
There's quite a difference.
Along with all the other recommendations, if it was stored outside check under the carpets for moisture.
Low miles does not always no worries.
Good luck. Graham
Old Oct 2, 2016 | 12:02 AM
My Vette Life's Avatar
My Vette Life
rotten bushings, Bad fluids, water leaks, mechanical issues, & signs of accidents.
This should be some things to look for.
Collectors don't keep a car for more than 2 years.
For those who just want o own it and dont drive it, they will tend to neglect even general maintenance.
Old Oct 2, 2016 | 08:09 AM
shutout's Avatar
shutout
Glad I posted this question. A lot of great advice. I will spend a lot more time going over this car than I previously would have.
Old Oct 2, 2016 | 08:15 AM
runner140*'s Avatar
runner140*
There is a great "sticky" at the top of the page....its a check list of what to look for when buying/looking at C5's.
I copied it when I made my purchase.
Old Oct 2, 2016 | 10:57 AM
speedmaster64's Avatar
speedmaster64
When I was shopping for a 2002 coupe about three years ago, I drove a couple of low mileage ones that looked great at first, but closer inspection even without taking them to a mechanic showed that both were clearly not quite right. Then when I drove both of them, they each showed signs of neglect, misuse, or maybe even accidents that had been repaired. It was strange in a way, because the mileage and the condition of the paint and interior were all so misleading, I supppose.
I ended up buying a 2002 with 71,000 miles that had all the maintenance records, had been driven up and down the coast by a retired couple on the same trip each year for 12 years. I had a Corvette fanatic/mechanic put the car up on a lift and spend almost two hours going over it front to back, top to bottom. It was so clear that this car was the one for me. Over the last two years it has been such an absolute pleasure.
So yeah. The mileage seems like a big red flag, and you need someone who really knows C5s to go through it front to back, top to bottom.
Old Oct 2, 2016 | 03:18 PM
shutout's Avatar
shutout
I'll check it out and see what I find.
Old Oct 2, 2016 | 03:24 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Perhaps it might help to save the final and more detailed inspection for the time AFTER you drive it. Getting it warmed up and bearings turning and seals and gaskets warming, it might reveal more issues than a static check cold.
Make it as long a test drive as you can without being weird
Your biggest safety concern might be the tires though so be careful, especially if it's wet.
Good luck man.....could be an OSSUM find or a garage queen gone bad.
Old Oct 2, 2016 | 03:26 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
I bought my 02 with 1,900 miles three years ago. I replaced all the fluids, tires and have not had any issues.
Good Luck!
Old Oct 2, 2016 | 03:40 PM
shutout's Avatar
shutout
Great idea!
Old Oct 2, 2016 | 03:42 PM
shutout's Avatar
shutout
Good Luck!
I hope I'm as lucky.
To 2002 corvette
