[Z06] Seats that sit lower
Old Oct 8, 2016 | 08:35 PM
Podium's Avatar
Podium
Default Seats that sit lower
Are there seats that put the driver position lower than the stockers? Is there a way to mod the stockers? Im 6'2 and most of my height is in my torso. I fit fine but I dont think I would fit to well with a helmet on. I was looking at the Corbeau A4s. I do not have to keep the power seats.
Old Oct 12, 2016 | 09:10 AM
Moto One's Avatar
Moto One
You can use an old Auto-x trick, and remove some of the springs in the seat cushion. This will give you a couple of inches, at the possible expense of some comfort (didn't effect me any).
Mark
Old Oct 17, 2016 | 11:39 AM
ggroller's Avatar
ggroller
Corbeau A4's are really nice. I've had mine for a few years now.
Once you pull out the stock seat frame rails and replace it with the one that fits Corbeau's you will gain head room.
Old Oct 17, 2016 | 12:15 PM
zdeckich's Avatar
zdeckich
2017 Corvette of Year Finalist
2016 C5 of the Year
FYI the corbeau A4's sit same height as stock. Maybe a tad taller. When I ordered my A4's I did the 1in shaved bottom. Helped out alot. I needed more room to wear a helmet.
Old Oct 19, 2016 | 09:16 AM
Podium's Avatar
Podium
Good to know. Im 6'2 with most of my height coming from my torso so head room can be a premium. I fit great in a c5 but Id like a little more for track days
Old Oct 19, 2016 | 09:23 AM
acroy's Avatar
acroy
I had A4's in previous cars; even with 'low' mounts and shaved cushion, I did not have much more room. I ended up having to remove the seat cushion & sit on the springs for track days!
Look at the Corbeau EvoX. About the same price, fits and looks great, much better headroom. I cannot recommend them enough.
Old Oct 29, 2016 | 03:11 PM
Bill Dearborn's Avatar
Bill Dearborn
The C5 seat bottom has a matrix type of spring with foam sitting on top of it. You can remove the spring but you stand a good chance of being very uncomfortable as the foam will be resting on all of the parts under the spring. If you have the memory seats the memory module is clipped to the spring. The memory module has to be in place if you have the telescopic steering wheel as the wheel will not move without the module being plugged in.
The lowest you can get would by using a fixed seat mount like the old Hardbar mount and an aluminum racing seat. That will get the seat bottom about 2 inches off the floor.
Bill
Old Nov 3, 2016 | 01:30 AM
dagon138's Avatar
dagon138
Check out
www.arizenracingsports.com
To Seats that sit lower
