C5R Splitter
My body shop is telling me that the vertical mounting section would hit the tires...my car is lowered on coilovers....don't know if that matters?
This is on top of the rear spoiler not fitting correctly (C-style)...if centered it hits one quarter panel properly...has a 3/8" gap on the other side.
All the best,
Michael
I was lowered nearly all the way on stock front bolts. Even raising the car a bit to prevent scraping would still result in hitting that area.
I used aluminum rivets and stainless wide flanged washers to secure the splitter to the front fascia. I lined my rivets up with the screws that hold the fascia together at the radiator air intake at the center.
Spaced three rivets.evenly on the corners as well.
