Stock C5 cutting power .. CEL
Old Nov 5, 2016 | 05:47 PM
Roddy13's Avatar
Roddy13
Default Stock C5 cutting power .. CEL
Hey guys I've been putting a bunch of miles on the C5 lately and it's been running great. Today I felt the power cut between 2,000 to 3,000rpm I was at moderate throttle 1st gear.
So so I drive for 5 minutes trying to replicate this and get it again in 2nd gear about 2750rpm ... Power cut hard enough to throw my head forward.... Now the car feels a bit dogish ... So I hit a quiet road and hammer down hard and it throws a CEL.
2 codes are on my scanner: P0137 and P0157 -- I believe these are downstream O2 sensors?
Why would my car have cut power so hard?
I did did plugs and wires 2 weeks ago so I figured it was for sure a cracked plug or loose wire. O2 sensors would not have been on my radar and how can downstream sensors induce a major power cut?
Any help is appreciated
Old Nov 5, 2016 | 07:05 PM
Roddy13's Avatar
Roddy13
Checked all the plug wires, they are seated properly.. Took out the maf and cleaned it... Turned car back on, CEL is off... I didn't clear though and went for a drive no issues, full power and no power cuts... I also data logged the drive and there was no knock retard events...
What is the best way to check for a cracked spark plug?
Old Dec 5, 2016 | 09:26 AM
nsogiba's Avatar
nsogiba
Take it out and look at it.
Plugs are cheap enough that you should replace any suspect units.
To Stock C5 cutting power .. CEL
By Michael S. Palmer | 2026-06-03 11:00:24
