My sons returned.
Old Nov 12, 2016 | 07:41 AM
sfc rick's Avatar
sfc rick
Default My sons returned.
Lucky me, my sons came by a couple weeks ago and pulled the block out of the car for me. I rebuilt it and yesterday they took time to come back and put it back in. They dropped it in bolted it back up raised the engine cradle and bolted that back to the frame. I can now finish the engine assembly and install the heads and everything else. Great to have grown sons who love working on vehicles themselves and take the time to help their Dad.
Old Nov 12, 2016 | 08:01 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Old Nov 12, 2016 | 08:04 AM
Black 03 Z06's Avatar
Black 03 Z06
Moving forward, well done guys.
Best of luck getting it all bolted back together.
Old Nov 12, 2016 | 08:34 AM
Tuco's Avatar
Tuco
St. Jude 15 Year Donor
From: Blessed are the cracked. For they are the ones who let in the light.
St. Jude Donor '08 thru '26
Old Nov 12, 2016 | 08:47 AM
to your sons for helping out. Good luck in finishing up and getting the beast back on the road.
Old Nov 12, 2016 | 08:48 AM
BRAVO1's Avatar
BRAVO1
VETERAN
That's great......
Jim
Old Nov 12, 2016 | 09:19 AM
Mickeyrx70's Avatar
Mickeyrx70
Originally Posted by BRAVO1
That's great......
Jim
Old Nov 12, 2016 | 09:21 AM
friou's Avatar
friou
So nice to hear! Good luck and best wishes going forward. Take care!
Old Nov 12, 2016 | 09:24 AM
yaknow's Avatar
yaknow
glad to hear your moving forward
Old Nov 12, 2016 | 10:24 AM
f6john's Avatar
f6john
What gives??? With all that extra help I would have thought someone would have been busy snapping pics!
Old Nov 12, 2016 | 10:30 AM
chassed's Avatar
chassed
Truth!^^^
Old Nov 12, 2016 | 12:19 PM
1Willy1's Avatar
1Willy1
I literally hate you guys who are able to pull/rebuild your engine like its changing a set of tires
bastards, the whole lot of you
Old Nov 12, 2016 | 02:27 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
That Vette needs to be on the Road !!
Old Nov 12, 2016 | 07:44 PM
El original's Avatar
El original
You are one lucky dad...but you did not need me to tell you that. Get her buttoned up and make some tracks. Oh, don't forget to take them all out for wings and beer, lol. Let us know how she runs.
Old Nov 12, 2016 | 08:04 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Sounds like you have raised fine sons who gladly help out their Dad.
Old Nov 12, 2016 | 08:26 PM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Family is what it is all about.
Old Nov 12, 2016 | 08:35 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
To My sons returned.
Old Nov 13, 2016 | 06:55 AM
sfc rick's Avatar
sfc rick
Just installed the Power steering rack yesterday and other parts, will continue to work on it again today. Shouldn't be but a few more days before it's maiden shake down run.
Old Nov 13, 2016 | 09:49 AM
f6john's Avatar
f6john
Remind me how deep you went into the block, what's new and what stayed.
Old Nov 13, 2016 | 12:55 PM
sfc rick's Avatar
sfc rick
All the way in. Removed the rods and once I started on the crankshaft I saw no wear on journals or main bearings so I just torqued them to yield specs and left good well enough alone. After pistons were inspected no discernable wear was apparent as were the cylinders with original cross hatching was still in there. So I just needed to hone them out and install new piston rings and rod journal bearings(they really were in great shape) since I had them out for the piston ring R&R. The piston skirt wear was almost non existent. I replaced both front and rear main seals and cover gaskets.
As it stands the block is as good as new and the car will be back up to specs once it is complete. These LS1's are almost bullet proof and this should last another 200,000 miles.
To be quite honest, the biggest problem I saw in this block were the 2 pistons which had the piston rings line up with each end gap. so with the oil control rings wore out they just became an oil pump letting too much oil get into the 2 combustion chambers on the passenger side. It was obvious by the short 5 minutes of running the new plugs that showed up fouled black with carbon from the excessive oil. Which was the over riding factor to pull the engine and re-ring it.
I also replaced the oil pump with the higher volume LS6 oil pump, and the timing chain. Although upon inspection the original oil pump and timing chain were completely fine. I just already had the new items on the bench and decided to just do them.
