Advis needed before attempting heater fix
From threads here that I have read it seems that I need to replace both driver and passenger actuators.
Before I purchase both actuators does anyone have any suggestions for what else I need to check, or do I need to replace the actuators.
Chilly in Illinois.
30 seconds to a minute to change both actuators.
Nothing else comes to mind - oh -- oh -- oh Since you have the dash panel off, change the Hazard Flasher. It's right there in front of you (after you take the entire dash apart).
My car exhibited that symptom years ago, but now I turn the **** slowly and all is well.
Any other idas would be appreciate.
The Dorman 604-106 is the replacement. The same one is used for the drivers and passenger side.
The dash pad has to come out to replace the passenger side. The drivers can be done by removing the IPC and the Bose audio processor under the dash.
Here are two links to dash removal instructions http://tech.corvettecentral.com/2013...-dash-removal/ and https://www.corvetteforum.com/forums...d-install.html.
There are two screws holding the actuators to the heater box. They have a 7/32 inch head on them. The drivers side can be undone with a nut driver. The passenger you will need a long extension on a ratchet. I have used a 1/4 inch drive 7/32 deep socket with a 4 inch extension to get the bolts out.
Let me know if you have any questions.
Gary
Gary
When you say "steps", how many are there and what are they?.
Gary
Bill
DTC B0361 Left Actuator Feedback Short to GND
DTC B0363 Left Actuator Feedback Open
DTC B0365 Right Actuator Feedback Short to GND
DTC B0367 Right Actuator Feedback Open
DTC B0432 Rear Defogger Relay Circuit
DTC B0433 Rear Defogger Relay Circuit
DTC B0441 Left Actuator Out of Range
DTC B0446 Right Actuator Out of Range
If you have any of the above and they are not clearing after pulling the fuse the actuator would need to be replaced. The fuse needs to be out for over a minute to discharge the circuit and force the re-index. The fuse to pull is in the passenger foot well fuse block and is for the HVAC system.
Gary
Then you can watch the actuator. They should spin move their shafts when you turn the temp dial up and down.
I had to replace mine twice. It's straight forward with the dash out. The reinstall takes longer. I've seen the difficulty exaggerated a few times on here.
Chilly in Illinois.
R&R driver Actuator, (installed OEM DELCI stock GM Part driver side), Open old Actuator (yes the Grear was broke off shaft)
Still throwing codes B0363 code, and B0441 .. Did not do passengers actuator.
The Driver side Actuator is constantly rotating, and under the dash view shows its moving.
I did R&R fues 27 with ignition on, and ac on and ac off.
I think the actuator can only go be installed one way, So must be computer not resting. Maybe Body computer? Is there anything other module / sensor in the loop with the actuator and head unit?
I see to many people with this problem. I must solve this mystery..
Also, where do you reside. Possibly there is a member in your area that can assist you with the troubleshooting.
Gary
I replaced the actuator tonight and I'm in the middle of reinstalling my dash. Removing the dash and reinstalling it really is easier than I thought it would be. If you have any questions, send me a PM.
