Having what sounds like a air leak somewhere on the intake manifold and cannot find it anywhere. I've been told it could be how loud the intake is on my engine. Anyone else run into this problem?
Were you able to find your leak cause I am having the same problem.
Any updates on this intake? How are you guys liking it? Which throttle body are you using and any before and after dyno's? Not much out there on this intake except for the LS7 fellas.
You could use some soap and water to find the leak.
Soapy water can help for exhaust leaks. But the intake manifold is under vacuum, so it's sucking in - not blowing out. Typically people use smoke or starter fluid to find intake leaks.
Yes smoke is better. Still soap and water will work for locating the intake/vacuum leak.
just swapped out my fast 102 for a mamo ported msd, lost 40 hp and 20 tq...but... I don't think it's the manifold, maybe motor is starting to go it's been run hard but going to put 102 back on and re dyno to see what happens and check some other things on motor
