Early EBCM
Old Nov 30, 2016 | 10:17 PM
jackthelad's Avatar
jackthelad
Default Early EBCM
I am confused. Autozone lists an ABS module for a 1997 C5 and states it is in stock, but nothing for a 1998. The manufacturer is BSE. I looked up the ABS system part number on gmpartsdirect.com and they show the same part no. for 1997 and 1998 - and the Autozone/BSE unit references that part number. But Autozone says there is no replacement available for 1998 cars.
For 1999, gmpartsdirect lists two units - with and without active brake control (part of AH, I assume).
If anyone can thrown any light on this, please do.
As I have an early '98 - 1st week of production, I am tempted to order the unit from Autozone and see what happens.
Old Nov 30, 2016 | 11:13 PM
Slo Yelo C5's Avatar
Slo Yelo C5
I'm wondering if they forgot to update their website.
Old Nov 30, 2016 | 11:21 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
how much ??
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Interesting. Hope it's true. I have a '98 that was made in May of '98 but doesn't have the active handling. Just the traction control. Wonder if it's the same one?
Old Nov 30, 2016 | 11:29 PM
mstromquist
This is what I just found on their Web site.
Blue Streak Elect Anti-Lock Brake Control Module
Price:$133.99
Core $54.00
Part Number: ALB1732M
Warranty: 1 YR
Notes: Remanufactured
OEM #10276650, 16257719, 16263481, 16265347, 9355246.
Order using the critical core program.
Old Dec 1, 2016 | 08:11 AM
grampi50's Avatar
grampi50
I'm interested to find out if this unit is actually available...
Old Dec 1, 2016 | 09:24 AM
JR-01's Avatar
JR-01
If it's the real deal, buy it.
Old Dec 1, 2016 | 10:09 AM
OCDvetteman's Avatar
OCDvetteman
Old Dec 1, 2016 | 11:06 AM
grampi50's Avatar
grampi50
FWIW, I put in a '98 C5 for this part and it comes up with "this does not fit your vehicle"...
http://www.autozone.com/brakes-and-t...hText=ALB1732M
Old Dec 1, 2016 | 12:18 PM
loufernh's Avatar
loufernh
Remember all 1997 corvettes had the EBCM mounted in the rear. Sometime during the 1998 model year, the EBCM was moved to the front. Could be the difference between the 1997 and 1998 part.
Old Dec 1, 2016 | 01:08 PM
Vette97sc's Avatar
Vette97sc
Ebcm is same its rear or front. If i remember right, bracket was different and one breakline connector was different. But those parts you can take from old ebcm.
Old Dec 1, 2016 | 05:28 PM
jackthelad's Avatar
jackthelad
My '98 shop manuals show it installed in the rear. Going to get underneath this w/e and take a look.
What we need to find out is at what VIN number AH was introduced, as that seems to be the change date away from this early EBCM. We are not supposed to post non supporting vendors URL's here, so if you are interested, look for "C5 build dates by VIN" with Google and it will aim you at part of the c5registry - organized by month.
Also, from everything I have read, it is not this ABS-only unit that is prone to failure, but the later unit with AH. Anyone confirm or deny?
Old Dec 1, 2016 | 08:02 PM
Lazarus Long's Avatar
Lazarus Long
Sure would be nice if was a replacement for an M code EBCM. Mine is an early 98, so for all practical purposes it is really a 97.
Old Dec 1, 2016 | 09:57 PM
MAC5's Avatar
MAC5
Originally Posted by 8VETTE7
Dec. 15, 1997 was an important day in the world of the C5 EBCM:
Last rear mount EBCM
First front mount EBCM for non AH cars
First regular production AH (RPO JL4) car with front mount EBCM:
http://www.c5registry.com/MembersOnl...n/98c5prod.htm
For (timeline) information purposes:
My 98's build date was 1/26/98, front mount EBCM ("M" model) without AH.
AH was not an available option at the time of my car order (12/11/97).
Old Dec 2, 2016 | 10:40 AM
mstromquist
My '98 Non-Active handling EBCM is an M model. My car was manufactured in May of '98.
Old Dec 2, 2016 | 11:41 AM
jackthelad's Avatar
jackthelad
It depends on the GM part number. The '97 replacement only covers certain OEM part numbers. That's what I will try to check on mine this w/e.
Old Dec 3, 2016 | 09:41 AM
C5 4 ME's Avatar
C5 4 ME
I'm confused. My vette was also manufactured in May of 1998. So it this a good thing or a bad thing.
Thanks.
To Early EBCM
Old Dec 3, 2016 | 04:17 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Or any other reason they wish to feed you.
Those aholes list everything as 'in stock'. Did the same thing when I was looking for a PCM. Said 'in stock', but after a few calls come to find out that not only is it not in stock, it's not going to be in stock either. They use a rebuild service for those, and if by the grace of god one comes in, you could put yourself on a waiting list to get it. But don't hold your breath.
Old Dec 4, 2016 | 02:49 PM
jackthelad's Avatar
jackthelad
I may just order one - I put one in the cart and clicked on check out, and it came up with a scheduled delivery date. Guess I'll drop into my local store this week and see what they say.
BTW, crawled under the rear and the EBTCM/BPMA is where the manual says it is behind the diff, but any sticker on it with a part number is long gone.
To Grampi50 - yes it says that it does not fit a '98, but the reality is that very early '98's (before AH was an option), had the same set up as '97's, with the ABS units at the rear.
Old Dec 4, 2016 | 04:03 PM
mstromquist
Thanks.
It's a good thing if you don't have the Active Handling. Mine just has the traction control and that's it. From what I've heard this version doesn't go out as often as the others.
