Help!!
Old Dec 3, 2016 | 09:35 PM
Edukejr73's Avatar
Edukejr73
3rd Gear
Default Help!!
Guys, brand new vette owner. 2001 C5. Received reduced engine power , and based on advice I received, I replaced the ignition switch. I have performed the VATS relearn, but engine still won't turn over. Acts like it isn't getting fuel, but I'm getting pressure on the rail. Here are the codes I pulled from the DIC.
PCM-No Comm
28-TCS-U1000HC
40-BCM-U1256H
58-SDM-U1000HC, U1016HC
i know that the U codes are related to communication, but I'm hesitant to pull the PCM and replace, as I haven't had any experience in flashing a new one.
Been messing with this car for a week, and I'm hoping you guys have the answer. Help is appreciated
Old Dec 4, 2016 | 11:28 AM
Edukejr73's Avatar
Edukejr73
3rd Gear
Ok, I pulled the battery tray, and no sign of acid spill. Connectors all look good.
No wetness in the passenger floor board. I
pulled the star connectors and no tarnished signs on the connectors.
Old Dec 4, 2016 | 01:00 PM
Edukejr73's Avatar
Edukejr73
3rd Gear
Too late on the ignition switch. It is brand new.
ill pull the PCM and see there is any damaged wires.
All fuses under the hood are good.
To Help!!
