[Z06] LS6 Supercharging
Old Dec 7, 2016 | 03:06 PM
CyberGray's Avatar
CyberGray
7th Gear
Default LS6 Supercharging
Can the GM LS6 motor handle 600 HP with the addition of a supercharger without any modification to engine.
Old Dec 7, 2016 | 03:27 PM
Quickshift_C5's Avatar
Quickshift_C5
Easily, with the proper tuning.
Old Dec 7, 2016 | 08:18 PM
95wht6spd's Avatar
95wht6spd
I have seen as high as 800whp stock block.
Old Dec 8, 2016 | 06:39 AM
StingrayRebel's Avatar
StingrayRebel
600 is a piece of cake as long as you have enough octane and the tune is spot on... a good set of valve springs and a timing chain are not bad ideas, maybe a set of rod bolts if you plan on revving past the stock limiter, but as far as the rotating assembly goes you don't have to mess with any of that
Old Dec 9, 2016 | 12:27 AM
KnightDriveTV's Avatar
0KnightDriveTV
Former Vendor
600whp and below...good to go. A bad tune can destroy any motor but, I ran a bone stock LS6 at 580whp and drove it like I hated its life...never skipped a beat.
Old Dec 12, 2016 | 12:57 AM
momo20's Avatar
momo20
should be no issue i would add some rear head steam port or steam line's as well as a meth kit to keep your temp's in check
To LS6 Supercharging
