Quick column lock question......
Old Dec 21, 2016 | 05:39 PM
ZR-1 Mark's Avatar
ZR-1 Mark
Default Quick column lock question......
Was this problem fixed in the '04 cars or should I install the by pass in the Spring ? '04 Z06#20685 with a January build date.
Just wondering,
THX
Old Dec 23, 2016 | 05:47 PM
ZR-1 Mark's Avatar
ZR-1 Mark
Originally Posted by 8VETTE7
With a Jan 04 build date the GM Column Lock Service fix would have been installed at the factory. But keep in mind that the GM Recall Service was a total piece of crap and and is NOT a permanent solution that prevents the column lock symptoms from occurring. A weak or bad battery or loose or corroded battery connections including at the starter WILL cause the column lock symptoms EVEN with the GM Recall Service done.
If I owned any manual transmission C5 I would order and install an LMC5 to prevent the column lock symptoms once and for all. I would also do the "optional" brown wire mod as explained on the 2nd page of the install instructions to avoid having to run into the "pull key and......" issue some time after installing the LMC5.
Thanks !!!!!!!!!!!
Mark
Old Dec 25, 2016 | 08:50 AM
steig's Avatar
steig
Do the LMC5 install. Cheap Insurance. Easy install.
Had to do the brown wire mod on my 2002 6-speed.
Old Dec 25, 2016 | 09:14 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Old Dec 25, 2016 | 10:36 AM
Tuco's Avatar
Tuco
St. Jude 15 Year Donor
From: Blessed are the cracked. For they are the ones who let in the light.
St. Jude Donor '08 thru '26
This ^^^ Cheap Insurance.
Old Dec 25, 2016 | 10:48 AM
LannyL81's Avatar
LannyL81
I have been wondering about the column lock in my '04 since I got the car in Feb; the steering wheel does not lock at all. I have no idea what or if anything has been done to it or if this is just normal operation of a '04.
Sooooo....just how is the column lock supposed to operate in a '04 with manual trans?
Old Dec 25, 2016 | 11:06 AM
radar502's Avatar
radar502
Well look in the fuse box the one in the pass. side in the foot well might have one in it that's were the LMC5 goes if it has one of these .. The column luck just tells the 04 to keep the column lock open that's about it in the manual does not tell the trans anything .. Sounds like you have one installed ,unless someone has removed the lock all together witch is very hard to do .
Old Dec 25, 2016 | 02:39 PM
LannyL81's Avatar
LannyL81
8VETTE7: Well I always wondered what that BZZZZZZT noise was upon turning the key...now I know, thank you.
Could you explain a bit further how the column lock would ever become a problem if a smaller diameter lock ring has been installed which prevents the column from locking....how would this fail and let the column lock.
ZR-1 Mark: does your Z06 make this noise?
Old Dec 25, 2016 | 08:46 PM
LannyL81's Avatar
LannyL81
8VETTE7: Thank you for the detailed explanation. It is defiantly the column lock motor and not the fuel pump I hear.
I followed what you wrote and I just need to take a look under the steering column now that I have a better understanding of what to look for. Pretty sure there is no LMC5 installed; I think I would have noticed that the last time I had the floor panel off...which was just last week.
I have had the dash all apart as I had to repair the HUD projector; did not work upon car delivery, but was not looking for anything under the steering column at that time.
I am convinced that I should just get an LMC5 and install it as a preventative measure.
So thank you again for taking some time and effort to reply; hopefully others benefit as well.
Later
To Quick column lock question......
