Do I have to Replace my TPMS's
Old Dec 22, 2016 | 04:56 AM
tmirisola's Avatar
tmirisola
Default Do I have to Replace my TPMS's
I am about due for tires on my 1999 Coupe. Aside from what tires I'm buying, do I have to replace my TPMS's???? They work fine. The overall car has 23k on the clock.
Old Dec 22, 2016 | 06:35 AM
mike48750's Avatar
mike48750
If they are original, I would to save having to do it in the next year or so. Mike
Old Dec 22, 2016 | 06:55 AM
runner140*'s Avatar
runner140*
I've been lucky....have the oem's from 2000....they will be replaced any time now.
Old Dec 22, 2016 | 09:55 AM
JR-01's Avatar
JR-01
It all depends if you want to wait for them to fail before you replace them. They might last a few more years, but they won't last forever.
Old Dec 22, 2016 | 10:25 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
and unfortunately they are the pricey ones, I bought the kit from Cultrag (2001 and later)and at the time was I thought pricey but it's nice having new key fobs that work more than 10 feet from the car. of course having the monitoring system working as it should, I am running non-run flats !!!
now the kits are really high
http://www.cultragfactoryparts.com/c...n/?parent=1001
Old Dec 22, 2016 | 11:00 AM
Velocity_Vette's Avatar
Velocity_Vette
With you owning a 1999 model you get to buy the pricey ones. There are two types used on C5s and unfortunately the Type 1 TPMS sensors are way more expensive - and cumbersome - than the Type 2.
While the TPMS sensors only function when the wheels are in motion (thus in theory a lower mileage car will have used the batteries less) age will be a factor since batteries do have a shelf life of sorts. You can re-use the ones you have now but don't be surprised if a year or two from now one fails and you begin to experience intermittent TPMS issues. Having a failed TPMS swapped out is not a big deal; it's just having to pay for the Type 1s which is a real PITA.
Old Dec 22, 2016 | 11:03 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
If original '99 sensors, they are past due for the batteries to fail.
I would definitely replace them. However, due to the higher cost of the early sensors you should consider the upgrade to the later system.
The kits can be pretty expensive as stated above. I did the conversion on mine for a lot less. I sourced a used RFA receiver, Ebay key fobs, and a Rock Auto closeout on Schrader TPMS (They made the OEM ones and are exactly the same except orange plastic instead of black plastic). The only thing I couldn't find a good price on was the connector for the new RFA receiver. On another thread it stated that a computer floppy power connector would work, however, the pin spacing was not quite the same and I didn't want to damage the RFA, so I spent about $20 for a connector.
I am happy with the upgrade to the new system and glad I did it, however you will lose the passive key fob option since the new ones did not use passive.
Good luck.
Old Dec 22, 2016 | 11:22 AM
UM Rebel's Avatar
UM Rebel
I've heard the batteries can be replaced. They are potted into sensor so I'm sure replacing is a real PITA
Old Dec 22, 2016 | 11:23 AM
66dts-v's Avatar
66dts-v
Mine have been throwing errors since I bought it 3 years ago. I have a right front that doesn't seal and loses about 2psi a day. If I ever get new wheels, I'll get new sensors.
Old Dec 22, 2016 | 11:34 AM
RED Coupe's Avatar
RED Coupe
Original owner, 2001 Coupe, 29K mikes, 16 years old. Work perfectly! Chevy parts people told me the 2001 or later DO NOT have a shelf life. If working leave alone. Very controversial view from postings on this forum but so far my experience bears their guidance to be accurate. We'll see I guess, but 16 years no issues.
Old Dec 22, 2016 | 11:39 AM
JR-01's Avatar
JR-01
The sensors do power down if not in use, so they will last longer in lower mileage cars. Mine were still working after 14 years and 50K miles but I did swap them out when I bought new tires. I got new ones for 30 bucks a piece, so it seemed like the logical thing to do.
Old Dec 22, 2016 | 11:57 AM
Fcar 98's Avatar
Fcar 98
Conventional wisdom says change them, But mine are 19 years old and still working with 47000 miles. I too bought the 01-04 replacement kit a few years ago and i will replace them next spring when i replace the tires. It is amazing how long they have lasted, when it was widely stated that they had a 10 to 12 year life span. I just left them alone as long as they worked. With this last set of tires being over 6 years old i can't see them going that much longer.
Old Dec 22, 2016 | 12:03 PM
UM Rebel's Avatar
UM Rebel
On battery replacement I found this video. It does indeed look like a PITA
Old Dec 22, 2016 | 01:53 PM
If it were my car, I would replace the sensors when the tires are put on. Yours may last a few more years, but you never know.
RED Coupe's Avatar
RED Coupe
Video is informative for pre 2001. Not applicable to 2001 and later.
Re 2001+ versions, I was told it uses the ABS system, TPMS is magnetic and uses ABS to signal measurements. Told this by Tire Shop that replaced my original tires at 29k miles. Told me leave alone since working fine. Similar explanation was given by Chevy parts guy. I could easliy have replaced them but I'm curious to see if this guidance is accurate. Now at 16+ years and no problem. We'll see????
Old Dec 22, 2016 | 02:06 PM
Rick Manning's Avatar
Rick Manning
Has anybody used these from Corvette Mods on 99s ?
C5 Corvette 1997-2004 Tire Pressure Sensors TPMS
Part Number:1558-2
Your Price: $49.99
MSRP:$57.98
Old Dec 22, 2016 | 02:31 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I try to FIX anything C5. So,,,,,,,,,,,, If it were me, I would just replace the batteries. It really isn't that difficult.
Bill
To Do I have to Replace my TPMS's
Old Dec 22, 2016 | 02:35 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I also like what QCVette's recommended. Its getting the TPM system Up-Grade at a very good price.
The newer 2001-2004 system works MUCH better than the early 97-2000 system!
Old Dec 22, 2016 | 02:56 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
not sorry I updated mine especially how much the Cultrag kit has gone up !!!
Old Dec 22, 2016 | 07:38 PM
jackthelad's Avatar
jackthelad
Tirerack has the early TPMS sensors made by Schrader (the OEM supplier to Delco) for $70 a pop. Not bad, as I bought new ones for my '98 (built 7/97) from them in 2012 and they were $68 then.
The OEM sensors were 14+ years old and still functional at the time, but were getting very slow to register, taking maybe 1/2 to one mile. The new ones register within a few hundred yards.
