Phase 2 - Planning
Old Dec 25, 2016 | 09:09 AM
Rsharpatx's Avatar
Rsharpatx
Default Phase 2 - Planning
A little back ground:
2003 A4 - so far I have just done the normal bolt ons.
Intake
1 7/8 ARH Headers No Cats
Borja Exhaust.
Tuned
The work will be done by Corey Henderson
I get to do 1 phase a year typically with a budget of 5-6k
End Goal will eventually supercharge down the road looking to max out at 600 to the wheels.
For phase 2 I was originally planning to do heads and cam but after thinking and reading and more reading I'm thinking of going a different route.
Instead of Heads and cam for phase 2 I was thinking of going a different route for this phase and do the following:
RPM Level 6 Transmission
Transmission cooler
3200 Stall prolly go with yank
3.42 or 3.73 gears
Will going this route cause any driveablitity issues. I put about a thousand miles a month on it half the month it's my daily driver. Have yet to put it on the track but I do drive the hell out of it.
My thought process is going this route is I can get a little more wild with the heads and cam when I get to phase 3.
Any advice/ ideas are welcome.
Old Dec 25, 2016 | 07:43 PM
blackmachdown's Avatar
blackmachdown
Phase 2 should be supercharger you will hit 600 with a decent sized pulley
Phase 3 new driveline
Old Dec 26, 2016 | 07:26 AM
IMXCITD's Avatar
IMXCITD
......that's what I was thinking when reading your post...why not go ahead and supercharge now and enjoy...you can do more on the next phase. (s/c, alky/meth, injectors/fuel pump, boost a pump and tune).
Old Dec 26, 2016 | 04:06 PM
RockyMtC5's Avatar
RockyMtC5
I don't know that you'd really need a torque converter without a cam, and if you plan on supercharging for sure then don't go any higher than 3.42 gears. Maybe some suspension upgrades instead of converter.
Transmission cooler
3.42 or 3.73 gears
To Phase 2 - Planning
