Sticky Shifter
Old Dec 26, 2016 | 08:46 PM
billy mild's Avatar
billy mild
Default Sticky Shifter
I drove my brother's C5 base model last night. It is a 6 speed manual with 131,xxx miles on it. First thing I noticed is the shifter doesn't not seem anywhere near as smooth as my C4Z. I noticed also that the shifter will stick in its position if you push it to the left or right while in Neutral. It doesn't naturally go back to the center of neutral. Is this typical in the C5 or just higher mileage C5's? Any thoughts on what to look at?
Old Dec 26, 2016 | 09:31 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
the stock shifter is junk, maybe yours was replaced ???
Old Dec 26, 2016 | 09:40 PM
billy mild's Avatar
billy mild
What would cause it to be "sticky"?
Old Dec 26, 2016 | 09:41 PM
El original's Avatar
El original
Not at all...post your question in the tech section for possible solutions.
Old Dec 26, 2016 | 09:43 PM
Billy, I would say that the shifter sticking to one side and not going to the center when in neutral is not normal. I have had two C5s with the six speed tranny and never had that kind of problem.
Old Dec 27, 2016 | 06:45 PM
C5Txfan's Avatar
C5Txfan
My 6sp stock shifter isn't the smoothest shifter I've ever had - it's a little 'notchy' but it doesn't do like the OP describes.
Old Dec 28, 2016 | 06:43 AM
3sACROWD's Avatar
3sACROWD
The C5 shifter is pretty notchy. This can be improved by performing the "anti venom" mod which is to place washers on the detent bolt on the transmission. Very quick and easy.
The stickiness is not right. Could be that the shifter could use cleaning/lubrication, alignment, or has weak centering spring. Cleaning/lubrication and alignment are easy. The centering springs are actually in the transmission so no easy access. If it is the springs, it may be easier to buy an aftermarket shifter with springs in the shift box.
To Sticky Shifter
