Gunked up throttle body?
Old Dec 26, 2016 | 10:21 PM
wildazme's Avatar
wildazme
Default Gunked up throttle body?
I put a cold air intake on my 2001 corvette the other day and when looking at the throttle body it was very fouled up with i guess carbon all on the butterfly opening. Is this normal? Anything i can do to prevent it? Car has 43000 miles on it.
Old Dec 26, 2016 | 10:41 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
There is no carbon in front of the throttle body.... just use some throttle body cleaner ( spray bottle.
Old Dec 26, 2016 | 11:16 PM
wildazme's Avatar
wildazme
Well said carbon for lack of a better word. It was black looking.
Old Dec 26, 2016 | 11:21 PM
Use what E-T said, it works very well.
Old Dec 26, 2016 | 11:24 PM
wildazme's Avatar
wildazme
Will do just wondering where it came from and anyway to prevent it. Thanks.
Old Dec 27, 2016 | 01:41 AM
Evil-Twin's Avatar
Evil-Twin
If you have an oiled air filter, it has too much oil.. it needs to be cleaned, or replaced. If you have a dry element, you might want to change it. you may have a modified air box or an after market filter. Just some reason for build up in the throttle body.
Old Dec 27, 2016 | 02:02 AM
wildazme's Avatar
wildazme
Everything was stock with the airbox.
Old Dec 27, 2016 | 06:57 AM
SG Lou's Avatar
SG Lou
There is no way to prevent it.....it's just the nature of the beast.
I'm running a bone stock motor with stock air filter and mine was, for a lack of a better word, carboned up around the throttle plate.
Get a can of the Throttle body cleaner that ET mentioned and clean her up !
You can go one step further...it wouldn't hurt to clean the sensor wire on the Mass Air Flow sensor.
I purchased a small can combo kit of both TB and MAF Cleaner from Walmart.
Old Dec 27, 2016 | 09:22 AM
kp1's Avatar
kp1
It's normal. I just spray carb cleaner on a paper towel and wipe the TB & blade with it. Just hold the blade open with a finger and go after the edges and back of the blade & TB throat.
Old Dec 27, 2016 | 09:55 AM
RockyMtC5's Avatar
RockyMtC5
What they said, totally normal and you should clean every now and then
To Gunked up throttle body?
