6sp reverse lock out ..
Old Dec 28, 2016 | 12:16 PM
C5Txfan's Avatar
C5Txfan
Default 6sp reverse lock out ..
I have had 2 previous C5's ('01 & '04) and now have an '03 vert with 10K miles on it.
I know that there's suppose to be a reverse lock out when going above 5 MPH or so. Well mine doesn't seem to work. I was driving the other day and went to shift into 6th and was apparently day dreaming and hit reverse with a loud gear grind ! Didn't seem to damage anything but now wondering what the issue might be of it not working. There is a back camera that was installed before I bought it and was wondering if a 'sensor' or something got messed up or disconnected when it was installed if that's possible. Not sure how backup cameras sense when shifted into reverse.
Anyone have any thoughts on problem ?
Old Dec 28, 2016 | 12:39 PM
98C5P's Avatar
98C5P
I have the same issue, I will be ordering a new solenoid
https://www.corvetteforum.com/forums...-lock-out.html
Rock auto has them and states the same solenoid for both M12 and MM6.
ACDELCO 19178634
Old Dec 28, 2016 | 01:05 PM
C5Txfan's Avatar
C5Txfan
ACDELCO 19178634
Thanks .. found the part on Rock auto !
Old Dec 28, 2016 | 07:28 PM
El original's Avatar
El original
I just had the same problem. Had it replaced at dealership $145.43 and half hour labor $75- They never heard of one failing. In reading the forum I guess it is quite common. Had tranny fluid changed at same time. Big difference, cost $170- (Dealership is now closed while staff on tropical vacation)
To 6sp reverse lock out ..
