C5 Lemans Headlight lenses
Old Jan 2, 2017 | 10:34 PM
Terminal velocity C5's Avatar
7th Gear
Default C5 Lemans Headlight lenses
Hello, i was wondering does anyone know where i can order replacement lenses for this type of headlight unit? i also circled a questionable area on the lenses where iam unsure if the previous owner cut the lens to make them fit correctly or if its the original design,
i attempted to contact breathless racing but the email address is not any good
Old Jan 3, 2017 | 02:59 AM
My Vette Life's Avatar
My Vette Life
wish I could help with the email address, but how do you like those headlights?
Old Jan 3, 2017 | 03:02 AM
7th Gear
There amazing
Old Jan 3, 2017 | 03:07 AM
My Vette Life
There amazing
really sweet. IMO Chevrolet screwd up with the pop ups. I think you can wrap the headlight with clear wrap. I've heard some exotic car owners doing it with the windshield.
Old Jan 3, 2017 | 06:39 AM
Rob 02's Avatar
Rob 02
You can clean them up with a clay bar.
Old Jan 3, 2017 | 12:16 PM
7th Gear
The drivers side lens has a huge crack in it,i wish there where a way to repair it
Old Jan 3, 2017 | 12:18 PM
7th Gear
Old Jan 3, 2017 | 12:40 PM
Rob 02's Avatar
Rob 02
I see it now. I wonder if a glass company could fix it the same way they fix windshields?
Then reinforce the edge by the bolt hole with something.
Old Jan 4, 2017 | 02:00 AM
Bob_VII's Avatar
Bob_VII
Try here for a mostly compatible lens, RadioFlyer is a forum bro here. The cut line you are referring to is original. That said, the Breathless headlights are garbage. The 4351 sealed beam low is anemic, and the high beam isn't even a high beam, it's a driving light. I ditched mine for the latest Stealth Light Cannons, which have their issues, but are much better than the Breathless. Now I'm working on something completely custom.
Old Jan 9, 2017 | 08:05 PM
Bob_VII's Avatar
Bob_VII
So, due to reasons, I have managed to break one of my lenses, too. I found out about one way that might work to repair them, depending on the type of crack. If the pieces fit flush without any gap whatsoever, you might be able to repair them with acrylic adhesive/solvent, Weld-On #3 or #4. I'll be trying it out in a few days.
Old Jan 9, 2017 | 10:07 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Our lenses are based on the same design, but use a different material. The BPP lenses are acrylic which resists scratches, but are prone to cracking under the slightest stress or impact.
Our lenses are an impact-modified acrylic which is more flexible and can take pretty good beating (as well as machining/drilling) but are slightly more prone to scratches.
That being said, Bob_VII is right. The BPP optics are no improvement over stock.
Old Jan 16, 2017 | 01:51 PM
SuperTom's Avatar
SuperTom
just get the radio flyer ones!
Old Jan 22, 2017 | 05:34 PM
scottieg74's Avatar
scottieg74
If the lesnes you have fit the breathless headlights. Im interested in a set
Old Jan 22, 2017 | 05:56 PM
TheRadioFlyer
Supporting Vendor
They will
We have some B-stock lenses (with VERY tiny optical imperfections) I can sell at a reduced cost if you're interested. Email: radioflyer97@gmail.com
Old Jan 22, 2017 | 05:58 PM
scottieg74's Avatar
scottieg74
Email sent
To C5 Lemans Headlight lenses
