Small Block, Big Block what is the differnece?
Old Jan 7, 2017 | 09:13 PM
Glen Green 65's Avatar
Glen Green 65
Default Small Block, Big Block what is the differnece?
What is the difference between a small and big black engine? The obvious answer is size, displacement but I read an article some time ago that went into measurement between the middle of cylinder bores and maximum displacement capability and some other data.
The LS engines have confused the issue and if you try looking elsewhere on line it is a zoo of answers.
400 ci small block, 396 cu big block, 427 small block and on and on.
So I came to the experts.
So does anyone have the definitive answer?
Old Jan 7, 2017 | 09:27 PM
ALLEGRO's Avatar
ALLEGRO
Using the minimum number of words, it all about bore-centers of the cylinders and the related geometry thereafter.
Stroke too can determine displacement, but torque and terminal revs are also relative to bore vs. stroke. Large(er) displacement / short(er) stroke engines rely on bore so the dimensions of the small-block limits many factors when you get into larger cubic inches
Old Jan 7, 2017 | 09:45 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
the term originated in the 60's by the physical size of the engine block. 283,327,350, small block. 396, 427,454 big blocks there was also a 400 small block. Pontiac, Olds. was the same, size of the block !! I don't think it pertains to the LS series cause they are the same size block.
Old Jan 7, 2017 | 10:09 PM
95wht6spd's Avatar
95wht6spd
I think all the LS would be small blocks. I don't think GM has put a big block in cars since the 70's, trucks maybe.
Old Jan 7, 2017 | 10:53 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
the 454 was put in a lot of trucks, motor homes,boats well past the 70's
Old Jan 7, 2017 | 11:09 PM
norcalace's Avatar
norcalace
Small Block and Big Block were descriptions assigned mainly to the "Big Three"; Chevy, Ford and Chrysler. IIRC Chevrolet initiated the monikers in the late 60s.
Basically it came down to small block = small bore, short stroke. Big block = large bore, long stroke.
LS blocks are just that LS blocks or LS series.
Old Jan 8, 2017 | 10:08 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
the bore and stoke had nothing to do with it, it was the SIZE of the block !!!! Like I posted earlier there was a 400 small block, big bore (siamese cyl.) big stroke !!
Old Jan 8, 2017 | 10:21 AM
narlee's Avatar
narlee
You can get 454 small block crate engines.
RBS_Z51C5's Avatar
RBS_Z51C5
Active Streak: 90 Days
Yep! It's very easy to eyeball the size difference between a small and big block.
There was also a 366 cu in Big Block, but they only put those in Commercial trucks.
The LS motors are definitely small blocks.
Old Jan 8, 2017 | 10:28 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
that is a LS engine !!
The LS based GM small-block engine is the primary V-8 used in General Motors' line of rear-wheel-drive cars and trucks. Introduced in January 1995, it is a "clean sheet" design with only rod bearings and bore spacing in common with the longstanding Chevrolet small block V8 that preceded it as the basis for GM small-block V8s. The LS' basic layout owes a good deal to Ed Cole's original small-block design of 1954-55,[citation needed] though it also uses cues from Buick, Oldsmobile, and Pontiac V8s. The basic LS variations use cast iron blocks, while performance editions are all aluminum with cast iron cylinder liners.
The LS small-block has been manufactured in three Generations – III, IV, and V – with preceding Generations I and II of modular GM small-block engines having been based on the Chevrolet small-block V8 originally designed in 1955. GM recycled the "LT" designation previously used on Chevrolet small-block V8-derived "GM" engines beginning with the LS Generation V "LT1" in 2014.
Several versions of the LS were used in the Chevrolet Corvette, beginning with the LS1 in 1997 through the LS9 and others in 2013. Variants of the LT version of the GM small-block have been used since.
Old Jan 8, 2017 | 11:05 AM
Forcedvert's Avatar
Forcedvert
valve covers/heads were the easy thing for me to see......much wider!
Old Jan 8, 2017 | 11:21 AM
norcalace's Avatar
norcalace
Don't want to get into a pissing contest but if bore and stroke had no play why did they produce two different size blocks in the first place? Makes no sense to do that just to do that if not to accommodate different bore and stroke configurations. If you look it up you'll fnd the LONGEST stock stroke available on the LARGEST small block is 3.750 on the 400 cu in version. The SHORTEST stroke on the SMALLEST big block is 3.760 on the 366 cu in version. Those numbers for the 400 are the best GM could do without clearancing the block. You can now easily take a small block up to 468 cu in with off the shelf components but you will still need to clearance the block and limit camshaft duration to prevent the rod bolts from hitting it. Big blocks can can go well into the 700 cu in plus range. If "the bore and stroke had nothing to do with it" why don't we see small blocks with big block cu in numbers? For GM to make 2 different size blocks for purely aesthetic reasons is a little far fetched for me.
Old Jan 8, 2017 | 11:30 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
we are talking the term big block, small block and the term came from the size of the block period !!!!!!!!
Old Jan 8, 2017 | 11:34 AM
Forcedvert's Avatar
Forcedvert
nobody is saying it is for looks! He is saying the "name" came from the size of block thus big "block", not big "cubes".
and yes Im sure it was done to go big cubes and be strong.
Old Jan 8, 2017 | 11:59 AM
norcalace's Avatar
norcalace
I'm sorry. I thought I was addressing the OP's question. I'm not lost on the concept of looking at the two and seeing one is bigger than the other but that's not the reason one was bigger than the other which is what I believe the OP asking. Maybe if they were a new design they would call them a Grande and a Venti.
Old Jan 8, 2017 | 12:30 PM
voda1's Avatar
voda1
Well they had other names:
big block == rat motor
small block == mouse motor
92GA's Avatar
92GA
Oldtimer
You can get almost any CI you want with aftermarket parts for the BB or the SB. But there is a difference between the two. The BB will have more torque because of the heavier rotating assy. The 400 SB was a truck engine, and that is why so many have survived. They had a short rod compared to all other SBs. You couldn't get a cam in one large enough to make them run with other SBs that's why they were over looked for many years. Without the aftermarket parts they'd still be boat anchors. Seen quite a few with the webs pulled out of them with the larger stroke cranks.
You can't run a 5.7 or a 6.0 rod in one without a small base circle cam with even a 3.75 crank. I had a 6.0 rod 406 that produced 658 hp that seen 7500 rpm quite a few times, 7000 rpm shifts for 5 years and still ran great with over 500 passes. Sold out a couple years ago, got too old.
To Small Block, Big Block what is the differnece?
Old Jan 8, 2017 | 12:50 PM
norcalace's Avatar
norcalace
Among others; Mystery motor, semi hemi, porcupine (all big blocks)
Which came first the Rat or the Mouse moniker?
Old Jan 8, 2017 | 01:10 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Good question, I guess you couldn't have a mouse motor without having a rat motor first ?????
Old Jan 8, 2017 | 01:17 PM
norcalace's Avatar
norcalace
Nope, wrong answer. Small block came out in '55.
Anybody else?
Hint; Chrysler Corp.
