Help Pricing a Rear Diff.
Jan 14, 2017 | 11:08 PM
I am looking for some guidance on what my rear diff is worth once removed from the car.
It is a 4.10 rear diff with hardened output shaft done by ECS out of an 02z. Diff. has about 24K miles on it with no issues of noise or leaks.
Jan 15, 2017 | 11:56 AM
Jan 15, 2017 | 03:05 PM
bump
I think I will probably just take it out and sell it outright. That way no one is waiting on my time frame.
Jan 24, 2017 | 01:33 PM
My differential is now removed from my car and drained of oil, FYI.
Jan 24, 2017 | 02:24 PM
Is it an ECS "stage" build, or built to C6Z or better components?
Jan 26, 2017 | 07:02 PM
Quote:
Originally Posted by
zeevette
The diff. was just pulled by ECS, the gear changed, and installed hardened shafts (also be ECS).
Jan 27, 2017 | 11:33 AM
My guess would be from $1250-1500.
Jan 27, 2017 | 06:01 PM
Thanks.
Bump for other opinions.
Jan 27, 2017 | 06:05 PM
zeevette
Jan 29, 2017 | 03:16 PM
zeevette
I would say that is a conservative range; could be worth another hundred or so.
Curious - what did you pay for it? And when?
Feb 26, 2017 | 06:10 PM
Sam Handwich
$1250 on special from ECS to remove my own stocker, change gears to 4.10, add hardened shafts, and reinstall.
I was thinking 1350+, so I am in the right range.
Feb 27, 2017 | 12:06 AM
I think you are probably OK with the price you are suggesting.
Feb 27, 2017 | 07:41 AM
Sam Handwich
Forgot to answer: this was years ago at ECS. 2009 I think. Prices for this work are higher now (it was a special anyway). I know as I spoke to Doug.
