Fluid Changes
Old Jan 16, 2017 | 11:59 AM
Kwalkr's Avatar
Kwalkr
Default Fluid Changes
Recently purchased an 04 with 33K miles. Car is immaculate which leads me to believe the previous owners maintained the car well. I have very few maintenance records so I am not sure if any of the fluids have been changed tho.,(except for oil....have those records). Although the car is 12 years old, it only has 33K miles on it. Should I change all the fluids....tranny (automatic), power steering, differential, brake or some of them and not others... Help.
Old Jan 16, 2017 | 12:31 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
it can't hurt to change the fluids, the brakes would require a Brake bleed using a Tech 2 . Dealer only, would be pricy. I feel it can be the most important fluid change, (EBCM flush)
Old Jan 16, 2017 | 12:35 PM
buckeye1872's Avatar
buckeye1872
I had brake fluid flushed and filled at dealer last year for my 99' for reason Pounder said. I think it was $89.
Old Jan 16, 2017 | 12:39 PM
chain_5001's Avatar
chain_5001
I would change out the fluids. Even though you have very low miles on the car the fluids could be 12 years old. Oils and additives do break down over time even if they have been just sitting.
Old Jan 16, 2017 | 02:19 PM
Mickeyrx70's Avatar
Mickeyrx70
When I bought my '02 Coupe I changed all the fluids. I think it's a good idea if for no other reason than to have a reference point for future fluid changes.
Old Jan 16, 2017 | 04:06 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
good point !!
Old Jan 16, 2017 | 06:44 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Don't forget to change the Dexcool.
Old Jan 16, 2017 | 09:32 PM
derz_vette's Avatar
derz_vette
I'd change these...
Brake Fluid
Transmission
Differential
Engine
Clutch (if manual - you state automatic so no need)
Power Steering
Coolant
Lube all joints/connectors as needed (all the things with zerk fittings?
Spark Plugs
Air filter
Old Jan 16, 2017 | 11:55 PM
If you do not have maintenance records to show what has been done to the car over the years, I would recommend changing all the fluids. Obviously if you have oil change records, that can be skipped.
I would also carefully check the belts and hoses and replace as needed.
Old Jan 17, 2017 | 01:08 AM
TheProsecutor's Avatar
TheProsecutor
I'd recommend these:
Brake Fluid - ATE TYP 200
Transmission - Amsoil
Differential - Amsoil
Engine - Mobil1 5W-30
Power Steering - Amsoil
Coolant - Prestone
Spark Plugs - AC Delco 41-110 & GMPP wires
Air filter- K&N
Old Jan 17, 2017 | 06:14 AM
runner140*'s Avatar
runner140*
I'm sure it was listed but it didn't jump out, so....change the hoses, they could be over ten years old or older. And yes, I realize we are talking about fluids but plugs and other non-fluid items came up.
Old Jan 17, 2017 | 07:07 AM
Kwalkr's Avatar
Kwalkr
Thanks guys.....always good info.
Old Jan 17, 2017 | 07:53 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I have to say like the rest of members here, it doesn't hurt but the pocket book, but if you have done, then you have record that you know it's all fresh fluid.
To Fluid Changes
