[Z06] Cam inquiry
Old Jan 18, 2017 | 07:22 PM
jbyrne213's Avatar
jbyrne213
4th Gear
Default Cam inquiry
Hi guys. I've been working with a guy at comp cams regarding which cam I should go with. A little background about my car. It's an 02 z06 with 52k on it. I have tsp 1 7/8 catless headers into the stock ti exhaust. I plan on running dual cutouts so I can quiet the car down on longer drives.
The guy from comp cams gave me two options to which he felt would be a great fit. The first being a 224/230 with a 114 lsa and the second being 227/235 with a 113 lsa. This would be my first cammed motor so I guess I'm polling the audience. What would major differences be? Do you guys prefer one over the other? Will I lose daily drivability 80 miles/week). Will I need to change my pushrods (currently stock) and oil pump? Looking for suggestions! Thanks in advance guys!
Old Jan 18, 2017 | 09:11 PM
kp1's Avatar
kp1
What's the objective?
Whatever it is, I would not recommend Comp. I have a sour taste from one of their cams taking a crap on me from having lobes that weren't properly hardened. There are better options from shops that atually check the cam to make certain it is manufactured properly before it ships out. There are also guys that can spec a custom grind for you based on your objectives.
Will it affect drivability? Sure.
Old Jan 19, 2017 | 01:10 PM
zeevette's Avatar
zeevette
You need to change your valvesprings anyway, ya know... I do like the specs of that second cam, but I agree with the above re: Comp. ( I am running one to be fair) My first cam way an off the shelf Crane that was 228-232@112/.600, and I loved it. Drove like stock, but had a nice lope. Also allowed me to reach 483/432 with great heads/ported FAST, etc., back when I was NA.
Old Jan 19, 2017 | 09:55 PM
Dave70's Avatar
Dave70
A ton of the "shop cams" out there are ground by comp to the shops specs. But yes on the pushrods. You wil need stiffer springs so a good hardened pushrod is recommended to keep them from flexing and bending under the extra load.
Old Jan 20, 2017 | 04:37 PM
jbyrne213's Avatar
jbyrne213
4th Gear
Thanks for all the help guys. I was sure about the springs but thanks for clarifying pushrods as well. I guess my biggest fear is either gping too mild or too wild with a cam. I drive the car probably 80 miles a week in nice weather...all highway. I just don't want to lose that every day convenience as well
Old Jan 21, 2017 | 08:58 AM
Dave70's Avatar
Dave70
just call one of the vendors on here and tell them what you want. they will be able to help you.
Old Jan 22, 2017 | 06:37 PM
apexslider's Avatar
apexslider
I daily my Z, rain or shine, and I have the BTR 227/234 113. I really like it. Nice mild chop to it and drives mostly like stock. It doesn't always parking lots, but who cares. Other than that, zero complaints.
Old Jan 24, 2017 | 11:15 AM
kp1's Avatar
kp1
That's his Stage II cam. I have his Stage III cam & for a dd or weekend driver, in my opinion/experience, it's a bit much for every day use.
Old Jan 24, 2017 | 11:17 AM
kp1's Avatar
kp1
They don't grind CamMotion cams and that was my choice on my last cam and would be my choice on my next cam.
Old Jan 24, 2017 | 01:23 PM
radar502's Avatar
radar502
https://www.youtube.com/watch?v=Cm-U...ature=youtu.be Comp harden cam 230/236 595/595 +4 112 LSA Ported stock heads Kools headers X-pipe V-Ram new springs push rods oil pump a few bolts ons 450 RWHP on LMR rollers drive anywhere . Not over done a fun Z to drive .. Just an FYI..
Old Jan 24, 2017 | 08:00 PM
turboffr's Avatar
turboffr
St. Jude Donor '10
Get in touch with Pat G and have him spec a custom cam for you, you won't be disappointed! It will come from Cam Motion...better core than Comp.
To Cam inquiry
