column lock
Old Jan 19, 2017 | 04:20 PM
namvet6869's Avatar
namvet6869
Default column lock
Trying to find out if column lock fix has been applied to my recently purchased 2000. With key out steering wheel does not lock. So I checked under passenger floor board, doesn't look like popular lock fix has been installed. After turning car off and removing key I do hear something happening in the steering column like something running for a split second. Can I assume that the lock plate has been removed or should I go ahead and install lock fix under passenger floor board??
Old Jan 19, 2017 | 05:53 PM
C5Txfan's Avatar
C5Txfan
If you hear the electric lock when it's turned off but wheel doesn't lock then some type of bypass / fix has been installed.
Old Jan 19, 2017 | 10:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100%
Old Jan 20, 2017 | 07:46 PM
mrlmd's Avatar
mrlmd
Just do it! $40 is cheap insurance that the problem has been correctly addressed and you can fuggadaboutit from then on.
Old Jan 20, 2017 | 08:30 PM
NimrodZO6's Avatar
NimrodZO6
2nd Gear
I believe my 2004 Z06 has some sort of deactivate device since the column is not locked with the key out, but every so often I see the 1-2 upshift light on my dash. Shouldn't that go away as well?
Old Jan 20, 2017 | 08:33 PM
namvet6869's Avatar
namvet6869
Just ordered the lmc5. Thanks everyone.
Old Jan 21, 2017 | 01:10 PM
C5Txfan's Avatar
C5Txfan
Do you mean the 1-4 skip shift light maybe instead ? The column lock and skip shift aren't related.
Old Jan 21, 2017 | 01:36 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% Even if the Skip Shift is bypassed or tuned out, you still get the light on the IPC. I call it a badge of accomplishment.
Just because your steering wheel doesnt lock, doed NOT make you safe from a column lock related issue. If the column lock system only has the dealer installed FIX,,, One day you will get into your car, start it up and go to leave and once the car moves, the engine will SHUT DOWN on the new dealer installed 2 MPH column lock fuel safety cut off....
You must install a proper column lock bypass to be free.
BC
Old Jan 22, 2017 | 04:47 PM
pmurray's Avatar
pmurray
When shifting from 1 to 2 I just use a little more rpms and good to go.
Old Jan 22, 2017 | 05:07 PM
kirk tarrant's Avatar
kirk tarrant
i pulled my wheel and used grinder to grind the lock tab off!
To column lock
