Yes, sir. They are Cray Spiders in mirror cut face/silver finish.
Jason at Getyourwheels.com made me a very fair deal for the rims with Hankook tires already mounted and balanced. All I had to do was pull car into the shop and make the swap.
Lookin real good, thanks for sharing the pics!
Post some new ones after its dropped
Lowering, hmmm. I'm not lowered and cautious as they come and I cringe everytime I hear it rub. I can't imagine it being lower and the cringe factor increasing!!
The first thing to rub will be that front air damn which has springs to retract back. A basic drop using just the bolts wont hurt anything. Its when you start chopping bushings and removing bolts you can go too low on the stock setup.
Tom, your car looks fantastic. How much did you lower? inch? inch and a half?
Mine is on Stance coilovers. The best way to go low is with coilovers and still have great ride quality.
reading my post above you can lower on stock parts by removing the front bolt or cutting bushings, and longer bolts in the rear. However ride quality will suffer even with new shocks. Been there done that. Coilovers really the only way to go!
