Oil Filter Question
Old Jan 27, 2017 | 12:38 PM
UM Rebel's Avatar
UM Rebel
Default Oil Filter Question
2004 CE convertible - I've changed oil many times but yesterday when I got oil and filter at AZ the filter they sold me was a Mobil 1 M1-107. Its much shorter than the filters I have used in the past but AZ dude insisted that is correct filter. According to my records I've been using M1-206. So the question is, what is the correct filter?
Old Jan 27, 2017 | 12:43 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
it's the one I use !!
Old Jan 27, 2017 | 01:03 PM
David Shiel's Avatar
David Shiel
Default Yep, for sure
Originally Posted by 8VETTE7
According to the Mobil 1 web site and their oil filter application search tool, the M1-107 is the correct filter for a 2004 C5:
https://mobiloil.com/en/product-sele...cgKEcpIChHQVMp
Don't know what the M1-206 is intended for........ If I were using a Mobil 1 oil filter (I don't) I would pick the M1-107....
I have used the 107 on all my C5s and have yet to leave a very large oil slick! Now it is clear!
Old Jan 27, 2017 | 01:05 PM
David Shiel
Default If Pounder uses it,
you cannot go wrong. Years of very successful mechanics work behind him.
Old Jan 27, 2017 | 03:47 PM
JR-01's Avatar
JR-01
You really don't want the filter hanging lower than the pan.
Old Jan 27, 2017 | 05:08 PM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
Ditch the Mobil 1 oil filters. Go to Napa and buy their name brand which is made by Wix Filters. Wix is far and away the best on the market. I use my 'free' Mobil 1 filters when I buy oil change specials for vehicles I winterize like boats. (The Mobil 1 filter stays on only for the winter.)
Old Jan 27, 2017 | 05:17 PM
JR-01's Avatar
JR-01
Is that your opinion or do you have and data to back it up. A Ford mechanic I know claims Motorcraft are the best by far and a GM mechanic I know claims AC/Delco are the best by far. Who do I believe?
I do use Delco in my GM vehicles and Motorcraft in my Ford. Never had a filter problem in 45 years.
Old Jan 27, 2017 | 05:50 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
The lsx engine was designed for longevity. An upgraded oil system, oil life monitor system Mobil 1 and an Ac Delco filter. The lsx was certified for 200. 000 miles. Before launch. This was a mandate by Dave Hill. It's the first engine designed to go 200,000 miles in testing. Been torn down and in non Distructive testing was certified that every rotating mass was within design tolerance. It's the first 200,000 mile benchmark in the industry.. prior industry standard was 100,000 miles. In the 70's it was 60,000 miles.
Proof is the hundreds of 200k 300k and 400 members who posted in a thread here a while back, and the countless Pm's I get from happy members who have following my advice. And report no internal issues..
I use Mobil 1, an Ac Delco filter and follow the OLM. or 1 year which ever comes first.. these recommendations come from world class engineers, with multi million dollar test ifacilities. There is a reason why the Lsx motor is the choice of professional builders world wide.. Of course modifications to the original design without extensive testing does not apply.
Old Jan 27, 2017 | 06:00 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
most top of the line filters have a guarantee against failure.
https://mobiloil.com/en/oil-filters/...ce-oil-filters
Old Jan 27, 2017 | 06:53 PM
David Shiel
Default And,
that is a primary consideration.
Old Jan 27, 2017 | 07:07 PM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
Everyone has an opinion here.
But my preference comes from the research and banter that has gone around and around on the boating forums I belong too. Over the years I have seen quite a few studies that all end up with the Wix with a slight edge over the Mobil1 based on flow performance and micron filtration size. It's been a while since I've read one, but there is plenty of info out there on the Internet.
https://www.google.com/webhp?sourcei...wix+oil+filter
Personally, I prefer the synthetic media to paper media, as the paper media is more susceptible to breakdown due to moisture in the oil, especially on vehicles that are not started/driven often. This is more of a problem on vehicles that have inverted oil filters, and as such anti-drainback valves are also of importance here as well. Regardless, for those of us that do not drive our Corvettes regularly, H20/Condensation in the oil system does have the potential to develop. The last few Mobil1 fiters that I have cut open and inspected personally have all been paper media. This has been at least a year since I have done so, so there could be changes/updates.
Old Jan 27, 2017 | 08:18 PM
ssrallyred's Avatar
ssrallyred
Just an example. A Valvoline VO58 oil filter would go on a C5. A VO108 would go on the same year's model Trailblazer with the 4.2.
The filters spec's are the same. One just has slightly more capacity.
I'm not sure on the Mobil filters but it might be the case.
Old Jan 28, 2017 | 12:51 AM
yanmar's Avatar
yanmar
Default oil filters
i have always used wix filters or napa, same thing. no problems. not trying to start a war of words but wix filters are common to NASCAR..........
Old Jan 28, 2017 | 07:40 AM
Omaha Flash's Avatar
Omaha Flash
Bill, Which A/c Delco filter is the correct one for the C5? I find the following listed, PF 44, UPF 44, PF 46, and PF 46E. Which is best and what is the difference?
Hope you are doing well.
Old Jan 28, 2017 | 03:05 PM
corgasm's Avatar
corgasm
There are dozens--hundreds--of sites that open up and analyze filters. Here's one, chosen more or less at random:
I think (can't remember 100%) Bob the Oil Guy recommended Purolator Pure One as the best filter
To Oil Filter Question
