[Z06] Diff up grade options swap or build?
Old Jan 27, 2017 | 08:29 PM
Podium's Avatar
Podium
Default Diff up grade options swap or build?
Hey guys. I plan on buying a 01 to 04 z06 in the near future. I have purchased the ECS brace and the pfadt brace as well. After I bought these, I saw that alot of folks are swapping to the c6 z06 stuff. Would I be better off returning those items and getting a used z06 c6 set up?
My plan is to use the two braces and then have the c5 diff upgraded with the c6 z06 guts. I want others opinions before I commit to that however.
The car will make between 600 and 700 rwhp. It will mostly be a street driven car.
Old Jan 30, 2017 | 10:04 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
It's at least $4,000 to swap over to a C6Z trans and diff along with the C6 cradle. And that's if you just buy OEM stuff from a recycle yard.
That said, it's tremendously stronger than th C5 setup.
If your just running hard on the street and not going to the drag strip on a regular basis, the C5 diff with C6 guts should be good enough for you.
Have fun with your project!
Old Jan 31, 2017 | 12:27 PM
zeevette's Avatar
zeevette
You also have to redo your exhaust system to accommodate the C6Z rear cradle, so costs will pile up.
To Diff up grade options swap or build?
