LS3 Swap pricing???
Old Feb 7, 2017 | 04:54 AM
Tsumi's Avatar
Tsumi
Originally Posted by jackthelad
So, you would spend rather more than the average C5 is worth. And you would still have an old car. Not for me. When mine dies, it will get replaced. IMO, it's just not cost effective to pour boatloads of money into it - and still be in trouble as the parts supply continues to dry up.
I prefer the lines and the look of the C5 over the C7. I also doubt that with how widespread the LS line is used and how interchangeable all of the parts are, parts aren't going to disappear anytime soon.
Old Feb 7, 2017 | 08:41 AM
Dirty Dog's Avatar
Dirty Dog
Considering that you can still get OEM and aftermarket parts for a 283 or a 305, which were never anywhere close to as popular as the LSx, I agree. I don't foresee any difficulty obtaining parts.
Old Feb 7, 2017 | 09:09 AM
Koufax's Avatar
Koufax
You guys are making me feel much more comfortable about spending $2.5k on a new set of wheels, that's for sure.
Old Feb 8, 2017 | 10:28 AM
jackthelad's Avatar
jackthelad
Try buying a steering wheel positioning sensor, or an early EBCM, or various seals and trim parts, etc. Or even OEM size tires for a C5 Z06.
Mechanical stuff, I agree will not generally generally be a problem, but in my fairly long experience of C5 ownership, it's not the mechanical bits that break.
The early C5's are 20 years old this year, don't forget.
Old Feb 18, 2019 | 08:18 PM
SivaSuryaKshatriya's Avatar
SivaSuryaKshatriya
Originally Posted by Scylla
Be careful about making sure that the electrical harness isn't a mess if you're going to buy something ala cart off ebay or whatever. As for the LS7, I'm a car nerd who kind of wants a 427 badge on her corvette. It's also the largest modern chevy block, so you can build the crap out of them, but no it's not cost effective at this time
Reviving this thread from the dead just to comment that as a C6Z owner, I would gladly swap my LS7 for a LS3 (which is how I found this thread). The LS7 is powerful but it also suffers from the following issues:
- Valve drop issue from bad OEM heads
- Bearings are iffy
- The titanium coating on the rods eventually wears off and can cause catastrophic failure
Even cars with the "fix" (AHP heads) still drop valves. My plan is to swap an LS3 into my C6Z when my LS7 lets go and supercharge it. For those wondering why I didn't just get a GS which comes with the LS3, it's because the C6Z isn't that much more expensive, and it has an aluminum chassis which saves a good amount of weight from the bottom, middle and top of the car, which probably makes a noticeable difference in the handling.
Anyway, anyone have an idea of the cost of swapping a LS3 into a C6Z? I'd imagine it's fairly easy, mostly plug-and-play?
Old Feb 18, 2019 | 08:25 PM
Tsumi's Avatar
Tsumi
- Bearings are iffy
Depends on what year you have. I imagine 2007+ should be a direct swap. Older might be tricky due to 2005 and 2006 being transition years, but not as tricky as LS3 into C5.
Old Feb 18, 2019 | 08:32 PM
KnightDriveTV's Avatar
0KnightDriveTV
Former Vendor
I've weighed buying a new Corvette repeatedly but...frankly I just can't push myself to do it. My car is plenty capable as it sits; full suspension, big brakes, plenty of power to have fun, and the car weighs under 3k lbs with 1/4tank of gas. I was just discussing with my gf again about this summer...she is likely going C7 GS, from her current C6. I think I'm going to just put 12k or so into my C5Z again and go with an HP research shortblock with a mild top end. The C5Z's in a well planted/well setup state, with 500-550whp, and an aftermarket traction control, would be a hard car to beat on the track, shy of big money cars.
Old Feb 18, 2019 | 08:43 PM
C5SCCA's Avatar
C5SCCA
AND...a C5Z is just a better looking car.
Old Feb 18, 2019 | 10:17 PM
SivaSuryaKshatriya
Good to know. I have a 2009, I'm mostly only worried about the dry sump, as I want to maintain it
Old Feb 18, 2019 | 10:39 PM
Tsumi's Avatar
Tsumi
I think you should be able to swap all of those supporting parts over.
Old Feb 18, 2019 | 10:51 PM
StingrayRebel's Avatar
StingrayRebel
I think you would have to use a manual grand sport or maybe a zr1 crank to keep the dry sump since the snouts are longer to accomodate the oil pump
Old Feb 19, 2019 | 01:16 AM
Krusty84's Avatar
Krusty84
Used L92 swap.
Freshen it up w/ a hone, rings and bearings (if needed) ~$3200
CNC port the heads ~$550
Add a nasty cam and spring package ~$750
58x to 24x converter box ~$300
DOD delete kit ~$250 (includes lifters and head gaskets)
Long tubes, if you don't already have them. ~
500+RWHP for ~$4500-$6500 if you do it yourself and depending on how frugal you are. You can find pull out L92s for less than I posted if you visit the yards on a regular basis.
Better yet... Sell your car and find a modded one at your desired power level.
Old Feb 19, 2019 | 05:07 AM
  #33
0KnightDriveTV
Former Vendor
^That pricing might be a little eager but...that's definitely a recipe. Don't forget you need intake/tb though also...that can add some dough.
Old Feb 19, 2019 | 12:06 PM
  #34
My Vette Life's Avatar
My Vette Life
Cheapest way is to build it yourself and search all over for the best prices on the web. It would be about the same cost as a ls1 rebuilt with heads, cam, intake, and a tune.
Not worth the money on the ls1 for less power.
You can build a stock ls3 with easy 430hp just to start with or put a bigger cam to get more hp. Also need tp think about trans and possible rear end in terms of gears. More hp = More $$$
Dont expect the stock tq converter if auto or stock clutch to hold all that power forever and not break down.
I plan on building a stock ls3 and have it in for few years and then bigger cam. Of course simple head mods port and polish will be added.
Old Feb 19, 2019 | 12:17 PM
  #35
acroy's Avatar
acroy
Vendors or other owners occasionally blow out a built, ready to use engine - I'd wait for a killer deal and jump on it then. A lot like building a car vs buying one built: cheaper to buy a built engine than DIY. All the little stuff adds up even if you score good prices on individual items.
FYI I have a LS2 based 427, 550hp on a relatively mild build. Friendly cam, good street manners. Lots of options these days for big displacement 500+hp builds.
Old May 9, 2025 | 08:11 PM
  #36
C5Shields's Avatar
C5Shields
Cruising
Originally Posted by ssrallyred
You can get a new LS3 engine with a warranty for 6750 all day from dealers on ebay.
http://www.ebay.com/itm/301991190784...%3AMEBIDX%3AIT
man just reading this post, $6750 now almost 10k. Inflation
