Convertible vs coupe vs Z06 structural integrity
Old Feb 14, 2017 | 08:34 AM
kdm123's Avatar
kdm123
Default Convertible vs coupe vs Z06 structural integrity
Does anyone know how much difference there is in structure integrity between a C5 Z06, a convertible, and a base coupe?
Has anyone ever done track days with a convertible?
I came across a Z06 that was converted by Caravaggio Corvette into a convertible. I thought this was a crazy idea. Do they reinforce the frame after they do this? Not sure what the point is since you can buy a convertible and just put on Z06 parts.
Old Feb 14, 2017 | 09:10 AM
Phanni's Avatar
Phanni
The frames are the same for all models of the C-5.
The only real difference is the 'halo' on the coupe.
Old Feb 14, 2017 | 09:18 AM
Gordy M's Avatar
Gordy M
While the rigidity of the C5 was very good, GM published studies on the rigidity of convertible, coupe and FRC. In the archives somewhere in CF was the published results but they were something like the Convertible were 22 hz, the coupe was 24 and the FRC was 27. The Corvette performance group wanted a structurally more rigid platform for T1 racing and other groups so they developed the FRC.
Old Feb 14, 2017 | 09:26 AM
C5Txfan's Avatar
C5Txfan
The C5 was designed with the convertible in mind even though they didn't have one the first year in '97. Thus the convertible had the same rigidity as the coupe - can't really speak for the FRC / Z06.
Old Feb 14, 2017 | 09:30 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Just an FYI, the hydroformed frame is 400% stronger than the C4 frame.
Bill aka ET
Old Feb 14, 2017 | 09:31 AM
jackthelad's Avatar
jackthelad
There is some discernible flex on the coupe. If you put your fingers across the roof/top of windshield joint while driving on a mildly bumpy road you can feel it. It's very slight, but it's there.
Is there a structural X-brace or similar built into the FRC roof, or is it just a body panel?
Old Feb 14, 2017 | 10:27 AM
ersatz928's Avatar
ersatz928
Bill aka ET
But the C4 frame was made out of Silly Putty.......
Old Feb 14, 2017 | 10:28 AM
ersatz928's Avatar
ersatz928
I think the FRC just had the Targa perimeter frame permanently bolted, or welded in-place.
Old Feb 14, 2017 | 10:32 AM
Gordy M's Avatar
Gordy M
The hoop on the FRC is also slightly larger than the one on the coupe plus the perimeter makes the entire car more rigid.
Old Feb 14, 2017 | 11:04 AM
Clairvoyantwolf's Avatar
Clairvoyantwolf
The convertible has "some" extra bracing to gain back rigidity lost by cutting off the roof. The FRC/Z06 is a convertible (thus the extra bracing) that has a fixed roof so it is ultimately slightly stiffer and slightly lighter than the coupe (less glass also helps with the weight).
http://www.corvetteactioncenter.com/...-corvette.html
Old Feb 14, 2017 | 11:09 AM
Bimmervet's Avatar
Bimmervet
St. Jude Donor '12-'13-'14-'15-'16
Most tracks will not allow a vert, to run unless it has a rollbar
In the Midwest that includes Autobahn, Road America, Blackhawk Farms, Gingerman,
Old Feb 14, 2017 | 01:20 PM
RSbeast's Avatar
RSbeast
The car was engineered as a convertible first; it's plenty capable. Just know most sanctioning bodies will require a rollbar with any open roof car if tracked.
Old Feb 14, 2017 | 02:38 PM
Sam Handwich's Avatar
Sam Handwich
Default why do you say it is a crazy idea?
There is a sticky on here about converting a hatchback to a convertible
https://www.corvetteforum.com/forums...nvertible.html
Putting Z06 parts on a convertible is one way to go. But once you look at the differences in the Z06 (there are a lot of them besides the engine - lightweight windshield, leaf springs, sway bars, etc.) you will see that your idea (i.e., buy a convertible and just put on Z06 parts) is the CRAZY one.
Old Feb 14, 2017 | 02:56 PM
Velocity_Vette's Avatar
Velocity_Vette
This is a valid point.
Any perceived advantages gained by say tracking a Z06 converted to a convertible like it sounds like the OP has plans for could conceivably be reverted when you consider that there is considerable structural measures to account for in a convertible. Even a roll bar with door supports is going to add some weight, as opposed to the stock halo with SMC body panel.
I would think there would be considerable issues also - someone could elaborate further - actually tech'ing the car. It's pretty much accepted when you track say a Miata or an S2000 that you're going to run a roll bar and there are rules for this, but a Z06 is a much different car from a base C5 convertible performance-wise, and you'd probably need to account for this in tech. At the least I'd think the car could possibly get bumped in class which may negate any advantages gained.
I feel if your goal is a track car you should just look for a normal Z06.
Old Feb 14, 2017 | 03:12 PM
charger21's Avatar
charger21
C5 of Year Finalist (track prepared) 2019
Wrong, the Z06 frames are aluminum.
Old Feb 14, 2017 | 03:28 PM
RSbeast's Avatar
RSbeast
Wrong. Only the c6z
Old Feb 14, 2017 | 03:30 PM
charger21's Avatar
charger21
Originally Posted by RSbeast
Wrong. Only the c6z
I was thinking C6, not C5.
To Convertible vs coupe vs Z06 structural integrity
Old Feb 14, 2017 | 03:39 PM
DRAFT1's Avatar
DRAFT1
Interesting. I found this that clears up a lot. What Bill said, with pictures.
http://www.superchevy.com/how-to/vem...rvette-frames/
Old Feb 14, 2017 | 09:14 PM
Tsumi's Avatar
Tsumi
Unless you plan to upgrade beyond Z06 performance levels. Then it's mostly a wash.
Old Feb 15, 2017 | 12:10 AM
Kelly.s's Avatar
Kelly.s
I track my 2001 vert. I put in a rpm roll bar and 5 pt harness. I had to lower the seat to get clearance. It's a bit old school but it works for me.
