[Z06] Valve Spring Anyone?
Old Feb 16, 2017 | 05:59 PM
WtrWkr's Avatar
WtrWkr
Default Valve Spring Anyone?
Hey Guys,
I'm the next valve spring failure to add to the list. 2002 Z06 with 361xx miles. Causing in 5th gear at 65MPH. Flashing check engine light and heard a ticking. I pushed in the clutch and coasted to an exit ramp. I knew it was bad so I didn't drive it, just tried to restart it hoping the issue cleared. Towed to my local shop I trust and it was on cylinder 6. Not sure which one. Anyhow, now I'm rocking some new "blue" springs. Engine is fine, so now
For the record, Build Date 5/02 and car number 31308
-John
Old Feb 16, 2017 | 06:41 PM
Potent68's Avatar
Potent68
I have less than 10k on mine and every time I take it out I'm nervous due to all of these failures. I'll be doing the blues here very soon.
Old Feb 16, 2017 | 07:39 PM
Josh67's Avatar
Josh67
I replaced mine shortly after buying my 2002. A little over $200 for the springs and a compressor then a few hours in the garage. If you do it yourself order a few extra spring retainers in case you drop one.
Old Feb 16, 2017 | 08:28 PM
MY03C5Z's Avatar
MY03C5Z
Sounds like you got very lucky, many times when one lets go the damage can be major. Replaced mine with new gm blue springs just after I got mine when it had 36k on it as well.
Old Feb 16, 2017 | 11:52 PM
WtrWkr's Avatar
WtrWkr
I wrestled with should I do this or not. After this scare I'm in the just do it camp. I paid to have it done but it was worth if to me. Lots of other guys can do it themselves and save tons of money. I will say this, new engine, 10K plus, replace valves, much less.
Old Feb 17, 2017 | 01:44 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Same here. In addition replaced valve seals, gaskets, spark plugs and wires. Why take a risk when the solution is so simple and not that expensive.
Old Feb 17, 2017 | 01:38 PM
WannaC5Z's Avatar
WannaC5Z
When I buy another C5Z if I see yellow springs in there I am forking over the cash to get the blues in immediately! What is the avg cost you guys are paying a Chevy dealership to do this?
Old Feb 17, 2017 | 05:20 PM
Paul 75 L82's Avatar
Paul 75 L82
Do It yourselve.
Old Feb 20, 2017 | 11:37 AM
Potent68's Avatar
Potent68
I went ahead and ordered my blue springs and valve guide seals. Everything will be here this week. Now I have to find time to do the install.
Old Feb 20, 2017 | 02:11 PM
WtrWkr's Avatar
WtrWkr
Old Feb 20, 2017 | 03:59 PM
racebum's Avatar
racebum
thankfully you were not at high rpm under high acceleration. from what i have seen that tends to be a killer
idle or above idle driving at light to no load rarely does damage as the remaining spring is able to keep the valve out of the piston
may consider replacing the valve seals while you are in there. $40 from gm and they take about 5 seconds each to change with the spring off
Old Mar 1, 2017 | 10:06 PM
Bobtam's Avatar
Bobtam
Default May not be blue
The replacement 04 springs may not be blue. They can be yellow just make sure they are the newer part number. 12499224.
Old Mar 1, 2017 | 11:11 PM
WannaC5Z's Avatar
WannaC5Z
What are you guys paying a shop to replace these? Parts $? Labor $? The car I just bought yesterday is a 2003 late year build so hoping it has the blues. How can I look in there and see them w/o taking the valve cover off? Does that oil filler neck twist ok safely?
Old Mar 1, 2017 | 11:40 PM
laurent_zo6
If you remove the oil filler cap you should be able to see the color of one of the valve.
Old Mar 2, 2017 | 08:03 AM
HONK 3X's Avatar
HONK 3X
I just did the updated springs in my car. It is easy if you have some mechanical skill. I just did it for peace of mind in my 2003 Z06.
Old Mar 2, 2017 | 11:24 AM
WannaC5Z's Avatar
WannaC5Z
Mine has some kind of filler neck that goes into there. It is different from my 2001 for some reason.
Old Mar 3, 2017 | 01:48 AM
laurent_zo6
Perhaps you can get your hands on a digital inspection camera.
To Valve Spring Anyone?
Old Mar 3, 2017 | 11:05 AM
WtrWkr's Avatar
WtrWkr
The filler neck comes off if I remember correctly.
Old Mar 4, 2017 | 10:27 PM
Trash's Avatar
Trash
Concur
Old Mar 5, 2017 | 04:20 PM
racebum's Avatar
racebum
thing you have to ask yourself is this. with the blue 16 spring kit available from gm perf parts for 65..
why would you ever buy singles and chance it?
