Oil leak?
Old Feb 16, 2017 | 09:32 PM
RREEVES's Avatar
RREEVES
Default Oil leak?
Went into garage this morning and saw a puddle of appears to be oil, probably about quart. The 2000 vette sat for about a week, has never any leaks at all. Amy suggestions of why and where it would be leaking.
Ron
Old Feb 16, 2017 | 10:26 PM
o2bnkc's Avatar
o2bnkc
First question is, where is the puddle at? A quart is a heck of a lot of oil to leak out sitting still. Are you sure it's engine oil? Just need a little better info.
Old Feb 17, 2017 | 04:54 AM
Rob 02's Avatar
Rob 02
I wonder if OP got the harmonic balancer/ front seal issue.
Old Feb 17, 2017 | 05:57 AM
RREEVES's Avatar
RREEVES
Sorry, appears to have started a few inches to the left side of the oil filter, probably wasn't a quart, but ran from the initial leak and ran to the back of the car from one side to the other. Car has about 35,ooo miles, oil changed regularly, never driven hard. It looks like oil, crystal clear and feels like oil.
Old Feb 17, 2017 | 06:12 AM
Rob 02's Avatar
Rob 02
Wherever it is actually leaking from and where you see it dripping can be two very different places.
Can you see under it with a mirror or anything. You are going to have to get it up to tell.
Old Feb 17, 2017 | 08:35 AM
RREEVES's Avatar
RREEVES
Thanks Rob, will check when it warms up a little.
Old Feb 17, 2017 | 09:24 AM
Glasact's Avatar
Glasact
Crystal Clear does not sound or look like oil.
Old Feb 17, 2017 | 09:30 AM
cbell3186's Avatar
cbell3186
A/C compressor oil/fluid? I have a "clear" oil leak only passenger side right on the cradle where the spring bolts to the cradle. Its not dark enough to be engine oil, nor does it smell like it.
Old Feb 17, 2017 | 09:38 AM
Rob 02's Avatar
Rob 02
The engine coolant would be slightly slick like oil. The coolant reservoir's is known to leak where the hoses connect. I replaced mine with a Dorman 603-140 that has metal inside that area. Check fluid levels.
Old Feb 17, 2017 | 09:46 AM
Rob 02's Avatar
Rob 02
Brake fluid is clear. You could have a leak in the brake hose (scary).
Old Feb 17, 2017 | 09:57 AM
JR-01's Avatar
JR-01
It first has to be determined positively what the fluid is.
Old Feb 17, 2017 | 10:02 AM
Red08's Avatar
Red08
Check to make sure the oil filter is tight, check the pan gasket, and the engine seals. If its motor oil, it has to be one of those
Old Feb 17, 2017 | 03:10 PM
RREEVES's Avatar
RREEVES
Upon further examination, I did a feel test between antifreeze and what was on the floor, I now believe it is probably antifreeze. I ran the car until the coolant tent went up to 215 and shut it down. I'll check for leaks when it cools down.
Thanks for everyone's response. I now need to find out where it's coming from based on the location.
Old Feb 17, 2017 | 03:29 PM
TXGS507's Avatar
TXGS507
Water pump or infamous coolant reservoir ( cracked at the T) would be my guess..
Old Feb 17, 2017 | 03:46 PM
knewblewkorvette's Avatar
knewblewkorvette
Dexcool has a red tint to it and tastes TERRIBLE, really bitter. Antifreeze is no longer sweet so it doesn't kill pets, etc.
I too have a coolant leak in my 02 but mine sounds minor compared to your's. I cannot find my leak, even with car in a lift
Old Feb 17, 2017 | 07:29 PM
Rob 02's Avatar
Rob 02
Check the little hose at the throttle body.
Old Feb 18, 2017 | 09:34 AM
RREEVES's Avatar
RREEVES
Little hose at throttle body?
Is this something I can see without car being on a lift?
Old Feb 18, 2017 | 05:42 PM
Rob 02's Avatar
Rob 02
Its at the top of the engine.
See the little hose?
To Oil leak?
