Installed Wind Restrictor
Old Feb 24, 2017 | 03:29 PM
gr1634's Avatar
gr1634
Default Installed Wind Restrictor
Finally got the wind restrictor Installed. Took about an hour.
Old Feb 24, 2017 | 03:34 PM
gr1634's Avatar
gr1634
Tried to put pics in right side up
Old Feb 25, 2017 | 09:47 AM
captaineddie's Avatar
captaineddie
How is it attached? Do you have to cut or modify anything?
Thanks.
Old Feb 25, 2017 | 01:16 PM
gr1634's Avatar
gr1634
Default Installed wind restrictor
Thanks.
Has mounts on each end that fit over the hump behind the seats. Connected to car with super tape (holds really well). Yes you have to cut the carpet on each side to get to the medal underneath. Carpet then folds up and over the bottom of each mount. Hope that helps
Gr
Old Feb 25, 2017 | 01:38 PM
captaineddie
Gr
Yes, that helps. I've been considering getting a wind restrictor of some kind. Thanks again.
Old Feb 25, 2017 | 06:19 PM
StrangelovesM6Vert's Avatar
StrangelovesM6Vert
I had the smoked one but found it didn't do much without the windows rolled up and even then it wasn't great plus it interfered with viewing out the back window with the top up so i took it out.
To Installed Wind Restrictor
