Rear Wheel Adapters.....NEED FINAL ANSWER !
I LOVE them and that's that !
I have done the search, read MANY threads and I'm not coming up with a conclusive, final, definitive answer.
According to charts I have seen, things I have read, the stock C5 Wheel offset is +58 mm in the front, +65 mm in the rear.
Stock C6 wheels are +56 mm in the front, +79 mm in the rear.
So if my calculations are correct, the front wheels are basically a straight swap. Ok, they are off by 2 mm, no big deal.
The rear wheels have a difference of 14 mm. ( 79-65 =14 )
Yet I'm seeing and reading about adapter width's anywhere from 20 mm ( 3/4") to 25 mm ( 1") being used in the rear.
Am I missing something here ?
What width adapter will I need to bring the rear tires out flush with the rear fender ?
If you can not locate a specific size, a competent machine shop will be able to machine down a spacer to your specs.
I figured its +14 mm. What I want to know is how does most come up with 20 to 25 mm width ?
As for Adapter vrs Spacers? A lot of guys here who put C6 wheels on their C5 use adapters. As long as it's a well made piece and the lugs are properly torqued there shouldn't be an issue. I have no plans on running road races or drag's. Cruising on the weekends and occasional shows is about the extent of my driving but thanks for the advice, noted and appreciated !
Most people go thicker than your calculations because of personal taste. To many, myself included, a more aggressive offset looks better than a weak offset. For this reason alone, they'd use a thicker spacer/adapter than what is required to simply bring it out to factory specs.
Longer wheel studs and spacers - pain in the butt.
Adapter that bolts on ( thats why it is so thick it has to clear current wheel studs and it has its own wheel studs built into it). I would run the ~20mm adapter and be done. It will push the wheel out 6mm, a quarter of an inch.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
bolt on deal, but you need to trim the unthreaded nose of factory studs.
Great quality, made in the USA to order.
http://www.motorsport-tech.com
frank
For reference here is my 2000 FRC on 2006 Base Wheels (19x10 rear, +79mm offset), using a 25mm bolt on spacer. I will be adding a spacer to the fronts as well to fill the gap. In my humble opinion the 25mm fills the rears perfectly. I prefer to have a "flush" look, maybe minus a few mm, to make sure there is no body contact under hard cornering.
New Schrader TPSM's are ordered along with a set of new Continental ExtremeContact DWS 06 .
285/35ZR19 for the rear and 245/40ZR18 for the front.
THANK AGAIN ONE AND ALL FOR ALL OF YOUR HELP.
