turn signals
Old Mar 14, 2017 | 12:03 PM
douger's Avatar
douger
Default turn signals
I have a 2001 corvette with the normal turn signal problem, about once a week they stop and I have to push the hazard flashers a couple times to get them going. I keep reading about a plug and play bypass that bypasses the emergency flasher. I have looked for one for several days to no avail. Does anyone have a part number or anything ?
Thanks this forum is great.
Old Mar 14, 2017 | 12:09 PM
FX VETTE's Avatar
FX VETTE
C5 Hyper Flash Harness. Forum vendors sell them or a Google search will take you to them.
Old Mar 14, 2017 | 12:38 PM
douger's Avatar
douger
Thanks, amazing what a difference it makes knowing the proper name. It took about 5 minutes to find and buy one.
FX VETTE's Avatar
FX VETTE
Old Mar 14, 2017 | 12:46 PM
Skyhawk23's Avatar
Skyhawk23
I had the same issue like you, my signal flasher will not work once in awhile. So I did some research and found the thread that show the by pass trick of the emergency flasher. It was pretty simple all you have to do is cut couple of wires and connect to an after market HD12 signal flasher. Then you are all set.
It took about 30 min.
Old Mar 14, 2017 | 04:25 PM
Old Mar 14, 2017 | 08:15 PM
sirdano's Avatar
sirdano
Or could do the mod yourself for 12.00. EL12 flasher.
https://www.corvetteforum.com/forums...problem-2.html
Please read all of post as there is one wire you dont have to cut
To turn signals
