[Z06] Oil burning issues???
Old Sep 25, 2002 | 12:08 AM
03QuicksilverZ06's Avatar
03QuicksilverZ06
Default Oil burning issues???
Do all the 2001's have the oil burning issues, or just some, does it carry on to the 2002's!!!! 2003's. .. :reddevil
Old Sep 25, 2002 | 12:21 AM
RPO_Z06's Avatar
RPO_Z06
Cruise-In III Veteran
St. Jude Contributor
Default Re: Oil burning issues??? (Silver"98z28vert")
My '01 doesn't burn a drop, I've heard its about 5% of total production.
You rarely hear about an '02 doing it, however I know a few people with '02's that use a qt. every 2k to 3k and thats well within the acceptable range for any performace engine..imho.
:cheers:
Old Sep 25, 2002 | 08:33 AM
Mobil 1aholic's Avatar
Mobil 1aholic
MY '01 burnt 10 quarts in 1000 miles. None so far on my 03.
Old Sep 25, 2002 | 10:33 AM
jerryv's Avatar
jerryv
Default Re: Oil burning issues??? (Mobil 1aholic)
:eek: :eek: Wow. By far the highest consumption I've heard of ...
My '02, w/9500 miles, seems to be using about a quart in 4000 miles. I'd also guess at about 5% of the '01s having the problem, but there's no way to know. In a perfect world, the manufacturer would make overall repair/problem statistics public, which would keep them honest and keep us informed.
Old Sep 25, 2002 | 11:14 AM
TopDog's Avatar
TopDog
Default Re: Oil burning issues??? (Jerry Velders)
My Z used to burn about 2 quarts every 1000 miles. I just got the re-ring done and not a drop in over 1000 miles. :cheers:
Old Sep 25, 2002 | 04:24 PM
VNAMVET's Avatar
VNAMVET
Veteran: Marine Corps
Default Re: Oil burning issues??? (TopDog)
Just perfromed my first oil change (2,000 miles) :eek: No issues here........ :D
Old Sep 26, 2002 | 07:09 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Check previous posts on the Forum. The oil useage is dependent on driving "style". If you hold a lot of rpms as you motor around town (ie. 3500-4000) then you will get ring flutter. Flutter doesn't occur at WOT.So basically all 2001 Z06s will do it (according to the experts) if driven in the stated RPM range. The fix by GM is to install a different set of rings (different desgn-doesn't flutter). Hope this helps - there are a bunch of excellent Threads archived on this topic. :cheers:
Old Sep 27, 2002 | 01:19 AM
Jhodel's Avatar
Jhodel
Default Re: Oil burning issues??? (binksZ06)
I get 2000 miles a quart on my 01 with 'normal' driving. I not worrying too much about it and just enjoying the car.
Jim
Old Sep 27, 2002 | 06:07 AM
SMFCPACFP's Avatar
SMFCPACFP
Cruise-In II Veteran
What oil burning issue? I have 17,500 miles on my 2001 Z06 and have only had to add oil one time (at about 7500 miles). :rolleyes:
To Oil burning issues???
