Engine strap ground
Old Mar 17, 2017 | 12:59 PM
jaoviedo's Avatar
jaoviedo
Default Engine strap ground
I need to replace the engine strap ground on my C5, looks like the heat from my headers damaged the ground and is now causing a short. I plan on buying the strap from autozone. I know the ground is located on the back of the block (driver side) but my question to you guys is, what is the best method for removing the bolt from the block? Space is limited and the bolt is at a strange angle. Thank You.
Old Mar 17, 2017 | 02:24 PM
UM Rebel's Avatar
UM Rebel
Just an idea. Why not find a more convenient place to attach the new strap and away from the headers?
Old Mar 17, 2017 | 03:12 PM
tbrowne's Avatar
tbrowne
The engine ground cannot cause a short. It may lose it's ability to ground the engine efficiently but it won't short out.
Old Mar 17, 2017 | 03:16 PM
jaoviedo's Avatar
jaoviedo
Yes sir, thats a given of course. Definetely making sure the ground clears all components next time. If you read my post again, you'll notice that I posted on the forums to possibly get some advice on how to go about removing the bolt on the back of the block with the limited space. Any advice?
Old Mar 17, 2017 | 03:32 PM
UM Rebel's Avatar
UM Rebel
Just another idea. Why not cut the old strap off and leave that bolt in?
Old Mar 17, 2017 | 03:38 PM
jaoviedo's Avatar
jaoviedo
I dont think you know what ground im taking about. Im taking about this ground.
Old Mar 17, 2017 | 05:27 PM
jaoviedo's Avatar
jaoviedo
[QUOTE=tbrowne;1594321250]The engine ground cannot cause a short. It may lose it's ability to ground the engine efficiently but it won't short out.
Do you happend to know the best way to go about removing the bolt from the bottom of the block?
Old Mar 18, 2017 | 04:09 AM
Rob 02's Avatar
Rob 02
You may need to go to Harbor Freight.
Old Mar 18, 2017 | 07:01 AM
tbrowne's Avatar
tbrowne
You get the car in the air, jack stands work fine, put a wrench on the bolt and remove it. Installation is the reverse. If the bolt is hard to reach, then you have to find a way. That's how I do things.
Old Mar 18, 2017 | 07:20 AM
LoneStarFRC's Avatar
LoneStarFRC
Bingo!
Old Mar 18, 2017 | 08:39 PM
UM Rebel's Avatar
UM Rebel
And sometimes "heat and hammers"
Old Mar 18, 2017 | 08:52 PM
UM Rebel's Avatar
UM Rebel
Old Mar 19, 2017 | 07:25 AM
v8srfun's Avatar
v8srfun
Use a flex head ratchet to remove the old one then install a different one in a alternate location. I added a ground strap on my car that goes from the lower belt tensioner bolt to the ground point right behind the right hood hinge
Old Mar 19, 2017 | 09:44 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I took these shots while installing my headers. The underside shot after installation, it appears that a swivel ratchet like the one pictured at Harbor Freight, I have one similar, should easily reach. Maybe put the socket on the bolt on the block first then snap the racket onto it. The top bolt is easily accessible from the top.
To Engine strap ground
