[Z06] Trans fluid
Old Mar 18, 2017 | 12:34 PM
DARRYLZO6's Avatar
DARRYLZO6
Default Trans fluid
Want to change the trans fluid and differential fluid. Read somewhere that we should stick with Delco brands for the Z. What's the GM brands and serial numbers? Thanks.
Old Mar 18, 2017 | 04:28 PM
Bobtam's Avatar
Bobtam
Use Amsoil Torque Drive auto trans fluid. No need to stay with GM fluids.
Old Mar 18, 2017 | 04:36 PM
oemtech's Avatar
oemtech
Veteran: National Guard
I would look at using Transynd 295... We used it in the Allison transmission in our RV behind a 8.1L Chevrolet. I have talked at length with the engineer the spec'd, tested & certified it. I used in my 83 Monte Carlo SS 350 auto trans and my 2010 Challenger 6 son Tremec 6060. Not cheap $40 a gal.
Old Mar 19, 2017 | 06:20 AM
Dan H.'s Avatar
Dan H.
St. Jude Donor '17
I use Amsoil severe gear 75w90 for the diff and Redline D4 ATF for the trans.
I found that trans fluid is trial and error. My car didn't like Royal Purple or Amsoil ATF. When I was searching the same question I found you can find posts for every ATF that will say it shifts like butter. There will also be posts for every fluid saying it didn't work. Its a matter of finding what works for your car. At 40 ish dollars a jug it can be an expensive and frustrating part of maintenance.
Old Mar 19, 2017 | 05:29 PM
skydiven4fun's Avatar
skydiven4fun
St. Jude Donor '13-'14-'15
Old Mar 19, 2017 | 07:00 PM
Trash's Avatar
Trash
2 qts AC Delco Dexron LS Gear Oil 75W-90 w/ limited slip additive. Part#10-4034 / 1#88862624. Transmission fluid 3.5 qts. AC Delco Dexron VI ATF. Part #10-9029 / 1#88861037.
No need to steer away from stock fluids either.
Old Mar 19, 2017 | 07:45 PM
tungstenfoot's Avatar
tungstenfoot
Ive been on similar trans fluid path...last was Amsoil, Redline going in this week, hope its a bit smoother
To Trans fluid
