[Z06] Cipher CPA2009 seat install.
Old Mar 20, 2017 | 11:20 PM
danh52's Avatar
danh52
Default Cipher CPA2009 seat install.
My 02 ZO6 is a dual purpose vehicle, both street and HPDE track days. The stock seats do not give enough support on the track so I have been on the hunt for a new seat. I am older so getting in and out is a concern so a fixed back race seat with fixed mounts just didn't make sense to me. While doing research I found a seat sold by Cipher that has suede inserts which would be a big help for sticking in the seat when on the track.
I have a well equipped shop so buying mounts wasn't an option for me. I knew that I would be installing C6 seat belts and I also integrated a set of 4 point Schroth Profi II ASM harness's.
I started by mocking up the seat position using wood spacers to determine the seat angle and height. I piece of 1/4" plywood stood in for the future steel plate.
Name:  plywood mockup.JPG
Name:  plywood mockup2.JPG
Name:  plywood mockup3.JPG
To get the seat far enough back for my legs I found there were 2 pinch points. One being the upper seat belt reel and the other was the inside tunnel where it flares out. I located the bolt locations for the seat tracks with the seat in the optimum position.
Name:  seat5 pinch point.JPG
danh52's Avatar
danh52
All the pieces are 3/16" steel, the main plate cut out using my plasma torch and the end mounts cut and bent using my press brake.
Name:  start other side1.JPG
Name:  start other side2.JPG
Next I milled slots in the main plate. I also cutout some areas to remove excess weight.
Name:  milling slots.JPG
Name:  mill slots2.JPG
Mounts are tacked in place and checked for fit. I am 6' and 225 lbs so I needed the seat to be as far back as possible with this seat and as low as I could make it so I had helmet clearance.
Name:  last fit check.JPG
Name:  last fit check2.JPG
I wanted to use the stock trim piece that covers the front bolts so I fabbed up some L shaped brackets and welded them on. That and some drilled holes did the trick.
Old Mar 20, 2017 | 11:21 PM
danh52's Avatar
danh52
I fabbed a mount for the seat belt receiver. I didn't get any pictures of the belts installed but the stud is long enough to sandwich the belt receiver 2 nylon washers and the Schroth belt.
One down, next I duplicated the design for the passenger side. It's a mirror image so just rinse and repeat.
Name:  drivers done1.JPG
Some primer and black trim paint and the mounts are done.
I modified the plastic trim panels to clear the seat adjust mechanism. This was a real pain to figure out requiring many test fits as I didn't want to cut too much. I also used a heat gun to form a recess to clean the seat back. In my case this is all hidden when the seat is in position.
I also tack welded button head bolts to the seat tracks so I could tighten the nuts without a second wrench.
Name:  track bolt tacked.JPG
Both seats are in and look great. I have enough leg room and plenty of room for my helmet. Now if the rain would only stop for awhile I could try them out on the road.
Old Mar 21, 2017 | 01:07 AM
toyotabike's Avatar
toyotabike
That is some nice work. I would have just bought backets instead of going through all that trouble.
Old Mar 21, 2017 | 01:52 AM
chain_5001's Avatar
chain_5001
Nice fabrication work. Thanks for sharing.
Old Mar 21, 2017 | 01:58 AM
JETZ's Avatar
JETZ
You've got some skills!
frank
Old Mar 21, 2017 | 01:11 PM
danh52's Avatar
danh52
Thanks for the comments.
My hobby is making things so buying brackets I can make was never a consideration. That said, it was a lot of work as I was designing as I went along. It would be easier to make a second set as I can copy the dimensions from the prototype versions. Not that I plan on making more. LOL
One feature I think the aftermarket should add to their offerings is the L shaped tab on the front feet that allows the use of the factory trim piece. It gives a more finished look to the install and is easy enough to add.
Old Mar 21, 2017 | 02:42 PM
chain_5001's Avatar
chain_5001
Thats the thing about spending thousands of dollars on tooling and developing the skills to use them. You can have things the way you want. It may end up costing way more and take two weeks but you got exactly what you wanted.
Old Mar 21, 2017 | 09:08 PM
*C7*'s Avatar
*C7*
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Dan, you should make me a set to help offset the cost of all your beautiful equipment.
If interested PM me a price. I'm not in a big hurry and could paypal in advance.
Thank you, Larry
PS I have a yellow 2004 Z06.
Old Mar 24, 2017 | 02:25 PM
danh52's Avatar
danh52
Thanks for the nice comments.
My brackets are made to fit the cipher seats using their bolt spacing and the seats themselves to determine the location of the slots. Fitting any other brand seat couldn't be confirmed by me (I don't have any others to try).
At this time I don't have any plans to make additional mounts but I hate to say never. Doing them the same way I did the first set would be cost prohibitive. Very labor intensive as all of the hand plasma cut edges had to be cleaned up with grinders and hand files.
If I was to do a larger run of parts I would put them put on cad and laser cut them. No clean up or machining required then. Without tooling there is still a lot of fit up required.
Old Mar 28, 2017 | 07:35 AM
nsogiba's Avatar
nsogiba
Very nice install, the front covers are a nice touch. I like the trick of using heat to mold that side panel, looks way nicer. I wish I had done that rather than cutting mine to fit the belts/seats.
Old Mar 31, 2017 | 08:25 PM
danh52's Avatar
danh52
Well, the weather has finely cooperated and it was dry enough to get some seat time today and I have some like's and some dislike's.
Like's:
The seats are very supportive and comfortable. Even during hard cornering and braking there wasn't any movement, very different from the stock seats. I'm 6' tall and 225 lbs with a large (read fat) waist and I have plenty of hip room, though the mid section of the seat back is tight.
Enough leg room for me, barely. Making my own seat mounts allowed me to put the seat where it had the most leg room. More on that later.
They look great.
Very happy with the suede inserts, wish they were a little bigger.
Dislike's:
The seat is not aligned with the center of the steering wheel. Due to the way the tunnel tapers, as the seat is pushed back it runs into the tunnel. To get the maximum leg room the seat had to move toward the door enough to be noticeable when driving. I moved the steering wheel further away than it was with the stock seats and that helped. A smaller diameter steering wheel would also help with the ergonomics, it's on the list of mods to complete before the summer track season. It's not a deal breaker for me at this point, I need to get more time driving before doing anything about it.
My upper back got a little sweaty, above the suede area where it's PVC. Not surprising since it won't breathe like leather. That's where more suede would be an improvement.
This seat must be wider or a different shape than other seats that look similar (such as Corbeau Evolution X) causing the fit issues at the back of the seat. It can work for up to 6' tall driver but not so much for taller ones.
Old Apr 4, 2017 | 11:13 PM
SuperTom's Avatar
SuperTom
Damn great work I wish I had access to all that equipment. The tab for the bolt covers is a nice touch.
Me being shorter I was able to keep mine tighter against the tunnel keeping it centered. A new smaller steering wheel will help as well plus will complete the package of feel on the road
To Cipher CPA2009 seat install.
