Wire problems need help
Old Mar 25, 2017 | 07:49 PM
meat85's Avatar
meat85
Default Wire problems need help
ok I have 1998 just got about month half ago been in and out of shop with mechanical stuff now that I have the car starting to see wires rather not going to any thing and the wires that go to the interior lights when you open hatch were taped but tape coming off look like might have started to melt I have pics of the one wire harness on passenger side in back connected to the light wires
Old Mar 25, 2017 | 07:52 PM
meat85's Avatar
meat85
Default Also found 5 of these in the back storage compartment
Old Mar 25, 2017 | 08:40 PM
SoAlVette's Avatar
SoAlVette
Look like spark plug wire heat shields to me
Old Mar 25, 2017 | 09:46 PM
SG Lou's Avatar
SG Lou
That's exactly what they are
Old Mar 25, 2017 | 11:19 PM
meat85's Avatar
meat85
Default Thanks
Thanks what about the wire picture
Old Mar 25, 2017 | 11:23 PM
meat85's Avatar
meat85
Default Passenger side in the back
This car is turning out to be a nightmare put money into a lot of mechanical work which I still have a leak only had this car 1 month in half I starting to miss my 85 I sold to get this
Old Mar 26, 2017 | 01:12 AM
El original's Avatar
El original
Here is hoping you get these issues fixed. We are all here to help if we can. Keep us posted and remember we all have had problems big or small at one time. You are in good company !!
Old Mar 26, 2017 | 04:10 PM
StingrayRebel's Avatar
StingrayRebel
did the wires get pulled out of the connector?... if that's the case you could get new terminals and crimp those on and reinstall the wires into the connector... if they got cut in half and there is still enough wire in the connector you could solder them back together and use heatshrink to seal them... caspers electronics, efi connection, and waytek wire are good sources for the correct terminals and you can get a set of metripack/weatherpack crimpers on amazon for about $20
Old Mar 26, 2017 | 07:49 PM
meat85's Avatar
meat85
Default Thanks
thank guys for the info just can't wait until everything is fixed so I can enjoy it lol
Old Mar 26, 2017 | 07:53 PM
meat85's Avatar
meat85
Default Not pulled out
it's connected but wire is bare
To Wire problems need help
