I have a base 97 and went with the C6 base OE shocks, because they are cheaper than the OE C5 shocks. They work great on bumpy roads, and autocross great. They are a good match for the softer springs than what the Z uses which what the Zo6 shocks are designed for. Stiffer shocks will not always make it better. Stiffer springs use a stiffer shock. Softer springs should use a softer shock. If the Z shock was ultimately the best, why didn't they use that on every car?
I absolutely love my Bilstein B6 HD Line..
the B8 is more sporty-stiffer
Mine is a 2000 Vert that is just driven, not tracked.
Great improvement over stock and not too harsh..
FYI , I did try the the Monroe OE Spectrum Replacements.. They work, but seem
mushy compared to The Bilstiens. Even more mushy than stock..
But they are cheap.. So depends on how you drive
